SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching
mode and in that give the straight mode the problem will be solved
SOURCE: Bernina 1630 problem
Your feed dogs sound like they are getting stuck,chec whether they are on the down position,and also make sure that you have cleaned any lint that builds up in the bobbin area, if all fails it will have to go into the technician,
SOURCE: I have a Bernina Activa
That sounds like the bobbin is not put in properly. check your manual.
SOURCE: bernina 1008 - tension problems
Make sure the presser foot bar is UP before you thread the machine, otherwise the thread doesn't connect propertly with the tension discs. Top thread should reel-off in clockwise direction.
SOURCE: Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
