SOURCE: Excel Formula
Use the round() function to specify how many decimal places you want to display. From the example you provided above, you could use the following formula:
=ROUND(SUM(A1:A4)*1.07,2)
The final "2" specifies that you want to display two digits to the right of the decimal point.
SOURCE: Venturer 5 CD Player
you have to take it apart to see whats obstructing it possibly inside.
Well seems it has lasted a long time with you, so you don't have much to loose.
SOURCE: My Kodak ESP 5 Won't print entire documents, only first page
Scott, If you are using Mac and Adobe 8 or 9, see solution from Kodak site at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=12998/7269&pq-locale=en_US
SOURCE: Belt Routing Figure for 1994 Toyota Landcruiser
CLICK on the following LINK. It has all the Diagrams for your Belt that you will need.
If you would: Before Clicking let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Thanks!
http://www.2carpros.com/car_repair_information/year/1994/make/toyota/model/land_cruiser/1994_toyota_land_cruiser_drive_belt_routing_diagram.htm
SOURCE: I REPLACED RCA D52W19 CAPACITORS
You have a bad flyback transformer. This is a common problem that eventually goes bad in the ITC 222 chassis. You have to get the model number with the code at the end of it after the /. And sometimes you must have the numbers from off the flyback itself. Try to contact MCM electronics for the flyback at 1-800-543-4330. First see if they can match it with the model number with the code after the /.
Testimonial: "YES SIR YOU ARE RIGHT YEAH THANKS FOR ALL THE HELP"
