Car Audio & Video Logo
Anonymous Posted on Jul 24, 2009
I have a Advent ADV35 mobile DVD player. When placing DVD in unit, it starts to load then rejects and will not play.
lddaddy
Level 1:
  • Contributor 20 Answers
  • Posted on Jul 25, 2009
lddaddy
Contributor
Level 1:
Answers
20
Questions
0
Helped
7322
Points
54
While the power is still on find the reset butoon (usally behind faceplate) once found push and hold reset button aprox 10sec (make sure you do this with something that is non metallic) see if that helps hope it does
Screen freezes when sd card removed
need wiring diagram for advent adv35 overhead tv system
Advent troubleshooting
ours did the same thing but kept the dvd, we had to replace it, dvd player gears went...
ADVENT ADV-35 wiring diagram
I need a wiring schematic for advent adv35 overhead 10' dvd player
Disc keeps getting rejected
see the cause and remedies and fix it: God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
see the block d. attached.
19helpful
3answers
My advent dvd player in my Yukon lets me load the dvd says loading then it automatically ejects it! How can I reset the dvd player?
my dvd player will not let me load a cd -- can "force: it in - takes it almost all the way then ejects it
1helpful
Will not play a dvd. When a dvd is inserted the screen says disc loading for a few (5-10) seconds then the disc is ejected. We had an identical unit that did the same thing about 7 months ago so we...
good day, regardless of the brand it maybe an optic lens problem but i suggest that you buy something branded, much better and worry free. hope this helps
3helpful
Advent ADV35 dvd player disk wouldn't eject, now won't load
Hello there:
I would first check to see if eye is not scratched or dirty and clean it if nesassary..
If you unplug the unit for a few minutes it should reset it's self.ok
and good luck on the drive i am a retired navy vet and know what you are going thru with the move.
best regards michael
(USN RETIRED)
Fast forwarding movies and listening to movies without headphones
https://www.manualslib.com/manual/2384/Advent-Video-Mobile-Adv38.html#manual There is no speaker in this unit, so it's headphones only. The unit is not wired to an always hot fuse. Find a fuse that is always hot even when cranking the engine and the player won't start the movie over.
Zenith DVB410 DVD player
I fixed it for good by sending the unit to DVD player heaven!
2answers
LG RH177 DVD recorder
same here but cant find a place to buy a new dvd drive any one help me
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
