Lands Phones Logo
a
al jelly Posted on Mar 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you register a uniden Elite 9135 handset to a Uniden 8155 base or vis versa?
Bill Boyd
Level 3:
Top Expert:
  • Uniden Master 53,816 Answers
  • Posted on Mar 24, 2017
Bill Boyd
Uniden Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11928912
Points
172802
Probably don't
the base and the hand set have to both be the same so the handset will be a 8155
contact uniden teck advice for the answer
How do I setup a Uniden Dect 5.8Ghz 8155+2 phone
Uniden XDECT 8155 + 2 Questions & Answers ...
www.productreview.com.au > ... > Uniden > Uniden XDECT 81xx Series
Uniden XDECT 8155 + 2: 25 questions and 38 answers on Australia's largest opinion ...and select Handset Setup or Base Setup. ... If you have a 2.4 ghz or 5.8 ghz modelphone use web address below. .... Uniden Premium DECT 31xx Series.
1helpful
Is the uniden 3105 additional handset compatible with the n32 base station? i was told it was by harvey norman, but it says registration failed..how do i do it?
It should register once it is charged and put into the cradle of the base station.the channels are selected automatically by the base station.the only time it doesn't is when you try using a handset for 2.4ghz system when the base is 5ghz or vice versa.
How do you register a old uniden SSE27 handset to a new Uniden SSE37 base
The following is taken directly from the SSE37 owners' manual:
Registering a handset
If you see a "not registered" message on a handset,
you must register it to a base before using it.
1.
On the base, open the menu and select
Register Accy.
2.
On the handset, press and hold #/DND
until the handset display says
Handset Registering (about 2 seconds).
3.
Wait until the handset display says
Registration Complete (about 30 seconds),
then pick up the handset.
If you don't hear a dial tone or the display says
Registration Failed, charge the battery completely,
then try again.
4helpful
Uniden phone stuck at searching, not getting a dial tone
One thing to try is deregestering your phone and registering it with the base again.
Hole the # and 'End' key on the handset until the next menu appears (about 5 seconds). Select deregister phone (use the 'Menu' button). Do it again, but select "base unavailable". After that, set them in the base (not the handset charger) and they should register with the base.
This works on most Uniden model phones.
3helpful
How do I register my Uniden handset? It keeps saying it tis searching and then out of range even though I have it on the cradle
Which Uniden phone do you have? Some should register with the handset in the base unit cradle for 30 seconds to a minute. Others need to be within a few feet of the base but not in the base charging.
For the models that need to be registered with a multiple step process, first make sure that the handset is fully charged; this could take 15 hours. (Make sure the battery is properly connected; if it is loose, the registration may fail. If the battery may have been sitting in a warehouse for months, you may want fresh batteries even for a new phone.) Make sure that the base is plugged in (power and telephone line). I like to check the phone line with a basic corded phone for dial tone if there are any issues with a cordless phone. With some Uniden phones, a registration problem can be cleared up by disconnecting the battery and then reconnecting it before attempting to register the handset. (Make sure that you do not have more registered handsets than the base can deal with. You may need to deregister all of the handsets and start over. Make sure that the handset is compatible with the base.)
The rest of the process requires you to have the handset close to the base and be relatively quick. (You need to tell the handset to get the registration information from the base and the base to send the information before they time out). For the D1688, at the base, you need to press Menu and go to the Register Accy submenu. Press Select. Then press and hold # on the handset you need to register until you see Registering Handset. Wait for the Registration Complete (or Failed) message.
For the DECT1060, the procedure starts at the handset. Press Menu and navigate to Add. Settings. Press Menu/OK and navigate to Register and press Menu/OK. Select the base number and press Menu/OK. Then press and hold the Find HS button on the base for 3+ seconds until the unit enters registering mode. Now on the handset, you need to enter a PIN that matches the one set for the base. (The default is 0000.)
If you still have problems with registering the handset, then it's likely that the transmitter or the receiver for either the base or the handset may have a problem sending and receiving the codes that synch the base and the handset. Most Uniden phones are not meant to be user serviced for this type of proble. You will need to contact Uniden if the phone is under warranty or decide if you want to replace or repair the phone through Uniden's support.
The manuals for all Uniden DECT 6.0 phones are available as PDFs from Uniden. See http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl for a list of all models or search for your specific model. On the manuals pages, the models are listed in numerical and alphabetical order.
I hope this helps.
2answers
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
1helpful
Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
2helpful
Two sets Uniden phones with base, second handset: incompatible?
I had the same problem with a Uniden 3355 handset and 2355 base. With the new handset I pressed "Menu" and selected "System Reset". I then Selected "Deregister HS" and followed the prompts.
Once this was complete, I returned to "System Reset" and selected "Replacing Base". Following the prompts, when it said "Register Handset" I put it in the base of the 2355, and within a minute it had registered, so both handsets used the base of the 2355!
S.
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
