Re: How to reattach front gasket spring on front door of...
Hello.
The best way to show you is by video. Try this link and let me know what you think. It is not your model but you will get the idea. http://www.youtube.com/watch?v=IgNP9ScdgDo
The rubber seal on your washer and similar front loading washers is a relatively easy repair. The seal is held onto the front washer panel and the fixed inside washer drum with separate spring-loaded rings that are reusable. So, don't throw them away! You need to remove the front ring from the front panel before you can remove the front panel. With the ring removed the gasket should be pushed into the washer; noting any drain holes, so that you can reinstall the new gasket in the same orientation. Once the outer ring is removed and the front panel is out of the way, you will have access to the ring holding the gasket to the drum. After the inside ring is removed, the gasket should pull off the fixed washer drum. You are now ready to install the new replacement gasket.
The amount of disassembly of the front of the washer is your option if it interferes with the installation. The door is usually heavy and it is useful to remove it from the front panel. Usually, a couple screws holds it in place. Removal of the front panel may also involve removal of the top of the washer and moving the control panel out of the way so that you can access the screws holding the front panel onto the frame of the washer. The locking latch may have to be temporarily removed but can be left in place if you simply push the front panel out of the way to have access to the inside gasket ring. It is useful to take pictures of each stage of the disassembly process to make sure your reinstall everything as it was.
Installation of the gasket starts with reattaching it to the fixed washer drum flange and then replacing the spring-loaded ring to hold it in place. Make sure the gasket orientation matches the original position. After the gasket is attached to the drum, you can now reinstall the front panel. If you unscrewed the latch mechanism when you took off the panel, now is the time to reinstall it as it can be manually held in place behind the gasket. The door can usually remain off the front panel until installation of the gasket onto the front panel is complete. Now bring the gasket forward and reinstall it on the flange of the front panel; secure it in place with the spring-loaded ring. Your gasket is now reinstalled. Simply reinstall the door and your repair is complete.
Tools needed include a blade screwdriver to help pry the rings off the gasket seal and one or two specialty screwdrivers (usually Torx or Philips) to remove the front panel.
You need to replace the door lock mechansim. Fairly easy to do yourself, just pull the spring strap off the rubber door gasket and remove 2 screws holding door lock. Install new door lock and re-install door gasket and spring strap, and WALLA! she works:)
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wiresto the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
There's a fault detected with the door lock and switch assembly. The door lock is not working or the door lock switch is not activated. This indicates that the door lock and switch assembly is malfunctioning and needs to be replaced to address the problem.
Disconnect
power to the washer and open the door. Remove the door gasket retaining
hoop by stretching apart the retaining spring at the bottom of the door
opening. Using needle nose pliers, start where the spring and wire are connected and pull the wire out of the groove of the door gasket.
Remove the three screws securing the door
lock and switch assembly to the front panel.
Gently peel the part of the door gasket near the door
lock and switch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock and switch assembly
behind the front panel.
Slightly lift the door lock and switch assembly then pull
it back off the front panel and out of the cabinet.
Transfer the wiring harnesses to the new door lock and switch assembly one at a time then install it in place behind the front panel. Secure the door lock and switch assembly and put the eased part of the door gasket
back into position over the lip of the door opening.
Check that
the door gasket is properly seated before putting back and securing the
retaining hoop around the lip of the door opening and the door gasket. Install the retaining hoop with the spring positioned at the bottom of the door gasket.
I can tell you how to fix one on the WF218ANW/XAA washer. Your model may be the same. You need to take the top panel off the washer by taking out two screws on back panel. You need to remove the control panel and place it on the top of the unit (it is attached with electrical cord). You need to talk out the detergent tray (press the clip in the middle). You then take off the front panel. it is not necessary to take off the door; however, to remove the panel you will need to remove the door latch mechanism on the inside of the door. To remove front panel, there are also two screws on the bottom of the unit. Once you have the front panel off, remove the old gasket by loosening the two springs rings. Pay attention to how the gasket is installed before removing. Replace gasket by installing inner portion first and replacing spring ring and tightening. Put all the parts back on the washer and install the outer portion of the gasket (with the spring ring). Samsung charges $130 to do this in my area and it's a pain in the neck.
The front panel does not need to be removed when replacing the door switch. What needs to be removed is the door gasket. Open the washer door. Get a pair of needle nose pliers then look for the retaining hoop securing the door gasket to the lip of the door opening. Stretch the hoop retaining spring at the bottom of the lip of the door opening then carefully pull the hoop out. Make sure not to tear the door gasket or else water will leak through it.
Remove the two screws securing the door switch to the front panel. Peel off the door gasket near the door switch then pull the door switch off the front panel and out of the washer.
Disconnect the wires from the door switch terminals then connect it to the new door switch. Secure the new door switch back to the front panel then put the door gasket back over the lip of the door opening. Properly secure the door gasket to the lip of the door opening with the retaining hoop.
front gasket/door boot.... replacement isn't easy but do-able. first remove three screws that hold front lower panel on and remove panel (where lint filter is). then remove 3 screws that hold on top panel (screws located at rear of top of washer), next remove 3 screws on top front of washer, then remove 4 screws that secure the contol panel. you must remove the washer door at this point, just a few screws and pin hold the door on. now, remove control panel by gently pulling the top away from the washer, it's held by a few plastic snaps. then, remove three screws that secure front panel of washer. now you're ready to remove the old boot/gasket. first look toward lower right side of gasket and pull the spring and remove wire that secures front of gasket. next... at about 3 o'clock on the gasket you'll find a longer screw (about 3 inches) that secures the rear of the gasket. loosen this screw until you can remove the gasket. remove the water inlet and hose from the boot/gasket.... now remove gasket from washer. you're ready to install new boot/gasket. find the small triangle on the new gasket and line this up w/the triangel at the top of wash tub. begin working the gasket onto the lip of tub, make sure to align the triangle and water outlets of the gasket w/the triangle and outlets of the washer tub. once back of gasket is on install the rear wire holder and tighten screw to former tightness. now work front of gasket onto the lip of washer, install spring wire to secure the front. place water inlet and hose into respective holes on the gasket. put front panel back on, put door on, put control panel on, put top on... and wash. like i said, not easy but do-able... i completed it in 1.5 hrs w/no instruction.
it goes on the groove in the gasket at the door , the side view of the gasket would be a V, it goes right in the middle. make sure the gasket is first snug on the metal frame groove. the spring is very tight, start at top then work down, use a flat screwdriver to pry it in at bottom. it may help to wet the gasket
If you haven't gotten a solution yet, I did this myself. It is pretty hard to remove the spring that is holding the gasket in place. Once you do that, just replace the gasket and reattach the ring w/spring.
