It doesn't come apart for cleaning like some gas ranges do. I frequently have to re-light it when I want to use it.
SOURCE: MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1
1. Watchdog on board
2. Touch membrane defective
To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board
F2
Oven too hot
Check oven temperature sensor
F3 F4
Open or shorted oven temperature sensor
Replace
F5
Hardware and watchdog circuits disagree
Replace clock assembly (also called the ERC)
F6
Missing AC signal
F7
Function key shorted
Replace touch pad
F8
Analog/Digital converter
F9
Door latch
Check door lock circuit
F10
Function key stuck
Replace touch pad
SOURCE: magic chef range
if you give me a model number i be might be able to help try here get your model number off the serial plate from the range http://www.maytag.com/support/manuals_literature.jsp if that dont work reply to this thread with model number
SOURCE: lighting pilot light on magic chef gas range
Hello Jim,
Try to replace the ignitor if it is more than 3 or 4 yrs. old..If it not that old then Turn the knob to the pilot setting and depress the handle. Holding it
down and at the same time, press down on the red button that sparks.
You may have to repeat this a few times. Once the pilot lights,
continue to hold down on the pilot knob for about 30 seconds. When you
release the knob, the flame should stay oN. If it does not, replace the
thermocouple. Once the pilot flame is steady, turn the gas valve knob
to on!!!..Thank you...
Hope this helps you!!...
Regards!!!....
SOURCE: Magic Chef Gas Range, model CGR3740ADW
magic chef fault codes
F1
1.
Watchdog on board
To determine
F2
Oven too hot
Check oven
temperature sensor
F3 F4
Open or shorted
Replace
F5
Hardware and
Replace clock
F6
Missing AC
signal
Replace clock
F7
Function key
shorted
Replace touch
pad
F8
Analog/Digital
converter
Replace clock
F9
Door latch
Check door
lock circuit
F10
Function key
stuck
Replace touch
pad
SOURCE: 1989 Magic Chef gas range digital display keeps beeping and says
This is a common failure in the control board. Here is an article that discusses the details.
http://www.fixyourboard.com/techzone/ovens/f1_error/f1_error.html
We repair a lot of these at www.fixyourboard.com, so you don't have to scrap out your oven.
