SOURCE: llike to clean the grill of the oven without any chemicals
I have an Zanussi oven with grill. The model is zbf360x and I would like to know the best and most effective way to clean it.
SOURCE: How to maintain my machine i lost my manuel
You can get the manual here:
http://www.retrevo.com/s/Bissell-1697-W-Vacuums-review-manual/id/10039bh340/t/1-2/
SOURCE: THE FAX MACHINE HAS WHITE OUT ON THE LENS-HOW
For ink on the glass use glass cleaner with ammonia, for whiteout, use isopropyl alcohol on a cloth. be gentle.
SOURCE: machine is unable to clean troubleshooting and routine maintain
Take the printer to a qualified printer technician, and pay the technician about $50 to properly "clean" it.
SOURCE: Impressa S9 keeps beeping "clean now". Have run
There could be several reasons for this problem but I can only think of the following:
1.) The internal sensor may have gone "bad". The sensors are sensitive and prone to failure. But before you give up, see #2 & 3 below.
2.) A few things to check:
- Make sure you are using the recommended white cleaning tablets*. If the tablets aren't used then there may still be oil build-up in the brewing chamber.
- When indicated during the cleaning cycle, be sure to remove the tray and bean container for at least 20 seconds and then replace, even if they are already empty.
*Cleaning tablets can be ordered from www.capresso.com.
3.) If you don't have cleaning tablets on-hand then you can try running a regular brewing cycle using white vinegar** instead of water. Follow with at least 2 cycles of clear water (to rinse) before brewing your first cup of java.
***This method is probably not recommended by your manufacturer. I have used it on my machines without incurring any problems but I can't guarantee that it's safe for your machine.
Additional resources:
The entire pdf instruction manual for your machine can be downloaded from the following website: http://www.capresso.com/pdf/s9_instructions.pdf
Good Luck!
