SOURCE: Sylvania MTS/SAP tv/vcr/dvd combo turning itself off
could be that either the dvd or the vcr are malfunctioning, usually it is the vcr that creates the problem. If you turn tv on and set vol to low see if you can hear the noise of the motor loading or trying to load,with out a tape inside. It may be a good idea to have a qualified tech repair it, these units are difficult to work on and further problems may come up if you are not familiar with the tv.
SOURCE: how can i switch my
kindly check the remote settings and your manual for it. Select Menu and click Settings, then sort it out until you see the option Wide so that you can select it to widen your screen..
SOURCE: tv picture fine : no sound
Check whether the mute button on TV or remote is jammed. Try using a headphone. Try changing the input device to something you know works for sure. If problem persists, it might need attention by a qualified service technician.
