SOURCE: wiring diagram
dave, the link below contains electric golf carts wiring diagram, one here is almost the same with your 08 Precedent like the one below.
good luck
Wiring diagram
SOURCE: golf cart smoking
It is most likely related to the rings, but running it would unstick them very fast if they were stuck. It's possible that sitting let rust develop in the cylinder walls and there may be some grooves in them now. They could also just be really worn cylinders. They make some oil conditioners which I wouldn't recommend on a car, but might work fine on a golf cart. I can't recall the name, but it was in a silver can, maybe called engine restore... You could always try that before resorting to a rebuild.
Testimonial: "thanks for your advice. I will try an additive before a rebuild."
SOURCE: Yamaha 4 stroke golf cart back fires all the
Very important... valves get out of adjustment and are easy to set. This is where I would start FOR SURE. Check out www.buggiesgonewild.com and an example of how to do it on EZ GO 295 http://www.buggiesgonewild.com/ezgo-gas-tech/1196-ezgo-295-350-engine-valve-adjustment.html
SOURCE: 1993 Yamaha golf cart Ser#
Hello
The serial number of the Golf cart does no good to ID it. I need the model number and the displacement of the engine as well as the number of cylinders and what year it was produced..
SOURCE: Can I leave my 2004 ezgo golf cart charger plugged
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
