The red reset button under the upper thermostat cover keeps tripping
SOURCE: Heater keeps tripping the reset on the thermostat
it's not the thermostat it's the element they are whats in the water and when the seperate thats what trips it,, you need to drain the unit with the electric off and do not turn the power back on till water is comming out of the hot side faucet they must be in the water before the power is turned on
SOURCE: I own a Bradford White
Hello. If you turn off the power and drain the tank then examine each of the heating elements you will find that the upper element is deteriorated. The fix is to replace the heating element. Actually though my practice is when one is bad the other isn't far behind so for a few dollars I change both when I have the tank drained. Joe
SOURCE: Electric 40 gal red reset button keeps tripping
You need to check your heating elements. also check for any loose wires as you may have a fire hazard as well.
SOURCE: hello, i have a reliance
Replace both thermostats and test both elements.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for Electric Hot Water Heater
heatman101
