SOURCE: DL-F code on HE4t washing machine
Google your washer by model and google the code list. It could be something as simple as the drain is clogged. We had the same problem. It was a simple fix.
SOURCE: IFB washing machine dryer not working
can you supply the enr?
first port of call is the overheat stat, switch off mains remove lid and in the middle top of the unit there should be a metal chamber that houses the dryer heater, somewhere there, you will see a stat that should have a reset button on it, if you press the button and it makes a definate click, it was tripped. There are some reasons for this, you may be stopping the dryer early and not letting it do the last 10mins which is a system cool down, the fan is not operating or slow, the unit is not draining properly (check pump filter) or you are trying to dry more than 2.5kg (half a load).
Good luck.
SOURCE: hello my ifb washing machine is
First of all the voltage to the motor must be checked when the program is on the wash mode. If absent then the program controller is faulty. However if there is voltage and the motor hums then the capacitor to the motor must be faulty and replaced. If there is no action then the motor can be faulty. Check also the belt , the spindle for free movement.
SOURCE: i have ifb elenaa washing machine. my problem is that water can't enter or drain from machine .help
make sure the water is turned on at the faucet handle behind the washer.
SOURCE: My ifb machine is around
my machine is the same model i got it from my daughter who is now abroad
the user manual is not there
i want to know how to use the programe knob
