SOURCE: intergrated doors
it is quite simple to remove the door panel .around the inside you will see some screws along the edge of the stainless steel panel .these are torx 20 bit size there are usually 2 or 4 that need undoing and are usually the 2 at the corner near the top and 2 half way down the sides these go through the panel and into the wooden door also on some models there are 2 along the side of the stainless panel hidden behind plastic grommets remove the ones from the edge first you can tell if they are the right ones becuase of the length try each one at a time if they are short screw them back in and try the next finally losen the ones at the side if you have them and the door will fall forward lift it upwards with the door slightly closed and it will come of the two metal clips at the bottom refitting is in reverse usin the old door as a template to measure and refit the brackets hope this is of assistance
SOURCE: Hi Guys, bought a semi-intergrated
Welcome to FixYa.
I`m not sure if you know the Neff dishwasher is built by B/S/H/ (Bosch).
That being said, I do have a complete installation guide for B/S/H/ built machines ( which obviously would work for yours )including custom panel instructions I can send you via an email attachment in a "pdf".
If you have reservations about posting your email on here let me know, I can give you my windows live email to contact me to send it to you.
The reason is the guide is about a 550KB file which is too large to post on here.
Let me knbow, I`ll watch for your reply.
Regards,
Macmarkus :)
