Speaker daisy chaining , am I going to damage my amp etc.?
The Peavey CS4080HZ is intended to place 2,040 watts
per channel into four-Ohm-rated speaker
impedances. The "HZ" suffix is intended
to state the amplifier has a relatively high
impedance output and is optimized for no
lower than four-Ohm loads. Are you strapping in Bridged or Stereo Mode? Bridged Mono Operation
Both amplifier channels can be bridged together to make a very powerful single-channel monaural amplifier. Use
extreme caution when operating in the bridged mode; potentially lethal voltage may be present at the output
terminals. To bridge the amplifier, depress the rear panel Bridge switch to the IN position. Direct the signal to channel
A's input and connect the speakers across the hot outputs (the "+" binding posts) of channels A and B. Only channel
A's input attenuator is active while in Bridge Mono mode. Both connectors are strapped together, so either connector
can be used with a patch cable to drive the input of another amplifier.
Unlike the stereo mode, in which one side of each output is at ground, both sides are hot in bridged mode. Channel A's
side is the same polarity as its input with the minimum nominal load impedance being 4 ohms (equivalent to driving
both channels at 2 ohms) in bridged mode. Driving bridged loads of less than 4 ohms will activate the DDT
circuitry, resulting in a loss of power, and may also cause a thermal (overheating) overload.
Therefore, check the impedance of the cabs for each mode. Remember, if you connect two individual speakers in Parallel (+ to + and - to -) you cut the impedance in half. Two 8 ohm speakers in parallel now have a load of 4 ohms. Series connection + to - to + to -, will double the impedance. Two 8 ohm speakers will have a load of 16 ohms.
I have actually taken a two speaker cab with a 4 ohm impedance and opened up the back to re-do the wiring. I rechecked the impedance with a ohm meter. So yes, be careful. Whatever you do, keep the speaker lengths as short as possible. Buy really good speaker wire or if you make your own, go with 10 gauge wire.
