SOURCE: Keyboard Reset?
try To download the latest drivers for the keyboard that you are using, visit the following Microsoft hardware Web site:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
If the issue occurs again, connect the keyboard to a different computer. If the keyboard functions correctly on a different computer, the port to which the keyboard was connected on the original computer may be damaged. If this is the case, contact your computer manufacturer to inquire about how to repair or replace the damaged port.
If the keyboard does not function correctly on another computer, the keyboard may be defective. If this is the case, and the warranty on the keyboard is still valid, you can exchange the defective keyboard for a new keyboard.
good luck :)
SOURCE: performance issues w/ Microsoft wireless comfort keyboard 1.0A model: 1027
try re syncing it to the base, press and hold the button on the base at the same time you press it on the keyboard and hold for about 15 seconds, then repeat but with the mouse this time
SOURCE: microsoft wireless laser keyboard 6000 v2.0 keyboard not working
You have to press the button on the receiver that is directly connected to the computer. While doing this, press the connect button both the mouse and the keyboard. I did this and now my keyboard is working, despite the battery indicator turning itself off a few seconds after I install it.
Hope this solves your problem.
SOURCE: my microsoft 1000 wireless keyboard is not working
You need to press the white button on the bottom of the keyboard.
