We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at [email protected] with your name, address, phone number and the model & serial numbers of the Dryer.
SOURCE: NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor. Check to see if heating element is OK.
SOURCE: whirlpool gas dryer no heat
The problem is probably with the ignitor...these are very fragile and burn out easily or crack...
Replace it and you will be working again...
Here is a tip on how to fins the part online...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
SOURCE: I have no heat in my dryer. How can I tell if it
check for continuity on the heating elements leads.
SOURCE: Whirlpool Cabrio - How do I tell if my heating
If you are comfortable useing a volt meter and a ohm meter I can walk you throught the steps otherwise you need to call a repairman, If you are not getting any heat and the tumbler is turning it is possible the element is bad again only a test meter can tell for sure or you can take the dryer apart and look at the element to see if it is broken make sure the power is turned off at the breaker first also unplug the dryer.
SOURCE: Whirlpool cabrio gas dryer does not turn gas on to
first change the ignightor if its a glow plug
