My brand new fisher paykel fridge, the door will not close on its own..soft closure? I had fridge leveled twice when installed. There is at least 6 more inches left and has to be done manually
Front raise 1 or 1 1/2 inches the side that is the door hinge side is 1/2 inch higher then the handle side. Tilt it on a slit angle towards the way that will force the door with the added weight of food on door shelf's. A perfectly level fridge is a useless fridge. If its only mission is for the doors to close from the maximum range its able to open.
SOURCE: Jenn-aire JJW8530dds
It might be because when the door was completely removed ( which they do rather easily for repairs and moving) it wasn't put back properly.
I would suggest you remove the oven door and re install.
You do not remove any screws or anything like that to remove the oven doors.
When you have the oven door open squeeze each hinge and shift then both outwards it will release the door from the hinge, the hinge stays on but the door will slide off the hindge. Afterwards check the alignment and reinstall the oven door
SOURCE: Refrig door gasket does not prevent gap when door is closed
Lift up the gasket and look for screws securing the gasket to the door.
Loosen all of these screws a few turns and twist the door in the direction needed to seal.
Hold the door in this position as you tighten the screws.
This can be tricky and sometimes requires multiple efforts.
SOURCE: water is forming at the front of our fridge by the door.
Sounds like your drain outlet in the fridge is blocked. Empty the fridge compartment and remove any obstructions from the drain hole at the back. Another way is to pull out the fridge and look for the hose that drips into a tray, lift it out and either clean it and blow back up it, or use some form of compressed air. cover the hole inside with a wet cloth first to catch obstruction ( usually food particles).
SOURCE: oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
SOURCE: 07kenmore elite bottom drawer gaps when fridge is closed
clean all of the freezer seals and all contact points.
