Canon PowerShot A620 Digital Camera Logo
Posted on Jul 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon Powershot A 620
Whenever I turn my camera (Canon Powershot A620) on, the lens opens and then immediately closes.
Anonymous
Level 2:
Scholar:
  • Expert 177 Answers
  • Posted on Jul 24, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
177
Questions
0
Helped
72346
Points
409
Check your owner / user manual. I had similar problem and it was caused by "Mode" and "Flash" settings.
Canon a620. no image on display and pictures turn out black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
1helpful
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
1helpful
Power Shot A620 Canon 7.1 mega pixel 3 years
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Black screen
Make sure that you read the reader's comments there for other techniques that may work if the outlined steps in the article don't. Also, please leave a comment there on how the fixes worked, or may not have worked for you.
1helpful
Cannon Powershot A-620 black screen can't review
Did you accidentally press the DISP or DISPLAY button on the back of your camera? This manually turns the screen on and off to save batteries. You would then use the optical viewfinder to take pictures. To turn the screen back on, just press this button one more time.
11helpful
1helpful
Canon powershot A620 black screen can't take pictures
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
1helpful
Lens cover will not close
YES, BUT THAT IS A JOB THAT NEEDS TO BE DONE PROFESSIONALLY, DUE TO THE ALIGNMENT OF THE LENSES AND THE POWER DRIVE FEATURES. IF YOU GOOGLE CANON POWERSHOT A620 REPAIR SERVICE, YOU SHOULD BE ABLE TO GET A PRICE QUOTE BEFORE YOU SEND THE CAMERA IN FOR REPAIR. IS IT JUST THE COVER THAT NEEDS REPLACED OR THE LENS? THE COVER MIGHT JUST NEED TO BE CLEANED GOOD WITH AIR TO START WORKING AGAIN? WORTH A TRY. IF I CAN HELP MORE, REPLY TO:
ARCLIGHT1217
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
