Computers & Internet Logo
samclaudia1 Posted on Mar 16, 2017
Gave access to a supposed Microsoft guy to remove threats. He wanted $200 to complete. I said no and when finished I was left with a need for a password for startup. I haven't the password
2 Related Answers
Anonymous
  • 2785 Answers
  • Posted on Mar 01, 2009
SOURCE: xps 200 stays stuck on the microsoft window startup
plz try to boot in safe mode, if you cant log in safe mode then you have to repair or reload your operating system
Anonymous
  • 3513 Answers
  • Posted on Aug 19, 2011
SOURCE: How do I remove my
Hi
Please check the bellow links to read the procedure:-
http://www.tech-faq.com/how-do-i-reset-an-acer-bios-password.html
http://www.wikihow.com/Break-a-BIOS-Password
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
How do I get rid of Restoro on my computer?
- Please download Malwarebytes to your desktop.
- Double-click mb3-setup-consumer-{version}.exe and follow the prompts to install the program.
- Then click Finish.
- Once the program has fully updated, select Scan Now on the Dashboard. Or select the Threat Scan from the Scan menu.
- If another update of the definitions is available, it will be implemented before the rest of the scanning procedure.
- When the scan is complete, make sure that all Threats are selected, and click Remove Selected.
- Restart your computer when prompted to do so.
2answers
How to remove/delete 'conduit.search.com'?
conduit.search.com is a adware.
I recommend that you install a good anti - Virus application and scan your computer.
For the time being you can use Malwarebytes. It works good for these Trojans. Please install it and then scan the computer. It would be better if you scan the computer in safe mode.
You can download Malwarebytes from:
http://downloads.malwarebytes.org/mbam-download.php
Additionally also scan the computer with Eset Online Scanner.
Eset Online Scanner
**Note** You will need to use Internet explorer for this scan - Vista and win 7 right click on IE shortcut and run as admin
Go Eset web page to run an online scanner from ESET.
  • Turn off the real time scanner of any existing antivirus program while performing the online scan
  • click on the Run ESET Online Scanner button
  • Tick the box next to YES, I accept the Terms of Use.
    • Click Start
  • When asked, allow the add/on to be installed
    • Click Start
  • Make sure that the option Remove found threats is unticked
  • Click on Advanced Settings, ensure the options
    • Scan for potentially unwanted applications, Scan for potentially unsafe applications, and Enable Anti-Stealth Technology are ticked.
  • Click Scan
  • wait for the virus definitions to be downloaded
  • Wait for the scan to finish
  • If no threats were found
    • put a checkmark in "Uninstall application on close"
    • close program
    • report to me that nothing was found
  • If threats were found
    • click on "list of threats found"
    • click on "export to text file" and save it as ESET SCAN and save to the desktop
    • Click on back
    • click on finish
    • close program
1helpful
2answers
When I try to access Facebook, wender hosting appears
Your computer is infected either with spyware or a computer virus, when you access Facebook it triggers the program to run. Download and run a virus/spyware scanner on your computer.
2answers
I help how to remove trojan/other virus from my window 7 laptop.please help me.
Here's a fee-based service to do it for you:
http://us.norton.com/nortonlive/
To detect the threat level, you may want to try the free (& advertised on TV) web site
www.MySafePC.com, but virus removal will cost $$ - they're happy to tell you you're infected for
free, though.
Here's Symantec's list of things to do:
If you suspect that your computer is infected with a threat or you receive a threat alert, and you want to make sure that your computer is secure.
You can perform a virus scan to eliminate any known threat from your computer. Scanning your computer for threats is easy if you follow the step-by-step instructions provided in this article. The scanning process may take an hour or more, depending on the number of files you have on your computer.
To detect and remove all the threats from your computer, follow these five steps:
• Install the latest virus definitions.
• Stop all running programs and temporarily disconnect the computer from any network.
• Run the virus scan.
• Install the latest Windows updates.
• Run a full system scan once again to ensure that there are no threats.
The first step is to check whether you can install the latest virus definitions, as some threats may block your access to all the security products' Web sites including Symantec's Web site. The subsequent steps vary depending on whether you can download the latest definitions from the Symantec Web site or not.
1helpful
Do you sell security (antivirus,antispyware,firewall ) if not which is the most compatable ?
Check out download.com (by cnet). I recommend two free programs. Look for and download Malwarebytes Anti-Malware 1.46 and also download Spybot Search & Destroy 1.62. Install both programs. Then make sure to check for updates and the latest virus definitions.
Reboot your computer and while it's beginning to boot up, press the F8 key to bring up the option to run the PC in "safe mode." Continue booting up the PC in safe mode. Run Malwarebytes first, choose the "quick scan" option. Use the program to elimate any threats found. It may require a reboot to complete the removal process. If so, reboot. After finishing with Malwarebytes, reboot PC again and once again enter safe mode. Run Spybot and when it's finished use the program to eliminate any threats it may find. Spybot may not be able to completely eliminate viruses active in memory and may ask you to let it run again on startup. If so, answer yes and reboot. After the scan(s), use the program to remove any of the threats.
You may also want to download AVG or Avast. They are also free (or at least have free versions) and are very popular.
Hope this helps.
2answers
I want to remove Genuine Microsoft Software from my desktop
To uninstall the Office suite do the following:
  • Click Start
  • Go to Control Panel
  • Open Add/Remove Programs or Programs and Features (for Windows 7)
  • Choose Microsoft Office in the list and click on uninstall
The uninstaller will then run. Just follow the instructions. When the uninstaller is finished your Office suite will be uninstalled.
Hope this helps!!!
6helpful
5answers
How to solve victim of software counterfeiting
ALWAYS BLACK SCREEN ON THE DESKTOP DUE TO VICTIM SOFTWARE
Vista network is not displaying completely domain members but sometimes it shows all computers of domain where as xp in neighbourhood shows all computers. server 2003 ent.
Microsoft Knows of the problem with Vista Network
Unfortunately,I got tired of microsoft making it illegal to tweak the OS to get it to do what you want it to do. (GO LINUX,GO)
I have been forced to use 3rd party software to properly map the network. (network magic) The software also allows me to control who accesses the open wireless we have by allowing me to treat anyone I want as a Threat and block them without securing my wireless.
Sorry I couldn't "Fix" the problem.
2answers
Malware threats
What your seeing is called Adware, they are trying to make you think you are infected to buy their software to remove it.
What you need to do:
Go to www.ewido.com a reseller of AVG, download the software and run a FULL scan once complete delete the threats its finds.
Thanks,
Cameron Bradford
www.pc-fix.us
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
