SOURCE: scanning
CHECK THE FOLLOWING FOLDER INTHE CONTROL PANAL;
DEVICE MANAGE[GREEN MARKS OKAY ANYOTHERS BAD, CLICK ON THEM.]
NETWORKING AND SHARING SAME AS ABOVE.
PROBLEM AND REPARTS, SERICUTY AND SYNC CENTER.
ANTI VIRUS AND FIREWALL MAYBE CAUSING ALOT OF YOU ISSUES
ROD
SOURCE: computer won't communicate with printer
Make sure that the printer driver you are using is compatible with your version of windows. If so, open all printers in "control panel" and make sure that this printer is the preferred printer and not an old one you might still have installed.
SOURCE: we are trying to reinstall
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
SOURCE: No computer will recognize printer.
Hello.
This can be caused when the internal circuitry of the printer is "scrambled", it can happen in a storm or surge and simply after age.
Unfortunately there is no quick fix other than getting a tech to have a look, but that can be more expensive than a replacement.
You have done the trouble shooting for us and ruled out a cable issue.
Sorry the news was not better.
Regards
GM
Testimonial: "Thanks... though this news (printer is dead RIP) sucks. =) Thank you for the prompt confirmation of T.O.D."
A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
