Microwave Ovens Logo
Michael Posted on Mar 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Magic chief mcd1611w powers up then shuts self down?
William Miller
Level 3:
  • Magic Master 9,179 Answers
  • Posted on Mar 16, 2017
William Miller
Magic Master
Level 3:
Answers
9179
Questions
Helped
4481336
Points
21747
It depends on how long it runs and the oven status (idle or dead?) when it shuts down.
It may be that the internal cooling fan is not running or is blocked, and that can cause overheating and thermal shutdown until it cools off.
For more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
[email protected]
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
1helpful
How do you access the light bulb in a Magic Chief Microwave MCD1611W
https://www.justanswer.com/appliance/9q0am-change-light-bulb-model-mcd1611-w-microwave.html
Quoting from link:
"Unfortunately the microwave will need to be taken apart to replace the bulb. You'll need a size T-20 safety torx bit screwdriver to remove the screws coming in from the back of the microwave around the right left and top edges. Start by unplugging the microwave. Then remove all the screws going into the outer shell and then the outer shell will pull straight back, up, and off. Now you have access to the bulb on the right side of the microwave cavity so you can replace it. The reason Magic Chef did this was because it forces you to unplug the microwave. Before they allowed you to change it by just opening the door and people wouldn't unplug the microwave which would cause the display board to short out when you replaced the bulb."
How do you change the light bulb in model MCD1611
MCD1611W New, popping popcorn in glass MW corn popper. 3-4 minutes to pop. After popped I open the door and after a few seconds the MW shuts down completely, no lights, no response to pad pushing.
Popcorn is a low-moisture food which can cause a microwave to overheat, as can a failure of the cooling fan or blocked vents.
You should always turn a paper plate upside-down on the turntable (slightly off-center for better heating) and place the popcorn container on top of that.
The paper plate elevates the popcorn for better exposure to the energy and protects the turntable from excessive heat.
Placing food off-center instead of in the center increases exposure to the energy and prevents the same spot on the turntable from being overheated repeatedly, which leads to material fatigue and cracking.
It's also a good idea to put about 1/2 cup of water in a 1-cup microwave-safe container in the corner of the oven when cooking low-moisture foods like popcorn, bacon, and potatoes.
The microwave's magnetron has a thermal protector (thermostat, TCO, or thermal fuse) attached to it.
If the magnetron gets too hot, it can be damaged or destroyed, so the thermal protector opens and disconnects the power to the whole oven.
If it is a resettable device, the power will be restored when the device cools. If it is not resettable, the device must be replaced.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
[email protected]
MCO153UWT shutting down after 3.5 minutes
it is an internal fan that is the problems, if this is a counter top MW just replace it. if Over The Range (OTR) and under warranty call for service. if out of warranty replace.
2helpful
Magic chef mcd1611st microwave oven,why is power gone it self off?
Check the fuse inside the microwave cabinet...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
My Magic Chef over the range microwave won't even pop popcorn without shutting down. Was told to put dish on sensor but it still shuts down. Any answers?
Magic Chef customer support recommends placing a glass of water inside the oven to absorb some of the energy. It works for us..Jan 1, 2010
1helpful
2answers
Shuts down for 5 minutes
I have the same problem with my new magic cheff over the stove microwave oven. I call magic chef and they gave me the 800 number for the service center (1-800-775-0202). When I described the problem they told me to just put a plate under the popper and this wouldn't happen anymore. I haven't tried it yet but here's hoping.
3answers
Oven turns off
You are running the risk of damaging the Magnatron by doing this.
Check the packets you are using, you will have to reduce your power output.
This is because microwaves act by being absorbed by water. There is very little in popcorn and in fat. Once this has been evaporated, the microwave energy builds up (as it is still being produced - but not absorbed), and ends up cooking the magnatron itself.
I have seen countless posts on here after cooking popcorn!
More fun on the hob anyway - and cheaper to buy in bulk!
13helpful
6answers
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Top Magic Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Magic Microwave Oven Expert? Answer questions, earn points and help others
