Question about eMachines Computers & Internet
Emachines D620 not booting
All I get is an orange screen with the cursor rolling over and over the boot options but the machine is totally unresponsive. None of the keys do anything and I've tried F2, F12, F8 and crashing I've taken the battery out and powered down - nothing! Can anybody help please? Thank you.
6ya staff
SOURCE:
nyilasrobert
Robert Nyilas
  • 627 Answers
SOURCE: I want to get into the setup mode when booting,
Enter Bios pressing F10 key and set the primary startup device to your CDROM
Posted on Aug 04, 2009
Anonymous
SOURCE: How to change the boot option in IBM 6578-PBU desktop
I searched for hours for a solution to this. Here it is:
1). Restart your computer, NOT using ctrl - alt - del
2). Press F1 when guided to.
3). When you get into the config menu, select Start Options, then hit enter twice.
There are all the options you need! Cool, huh?
Posted on Sep 06, 2009
Anonymous
SOURCE: keyboard failure
http://www.youtube.com/watch?v=9MlWAJ0Y0Yg
watch it and bam solved
Posted on Sep 23, 2009
Anonymous
  • 788 Answers
SOURCE: Acer Aspire One - blue screen only when try to boot
You may have to remove and reset the HDD and Memory on the unit.
Next, you will recv. the F-2 to continue or F-12 to enter setup.
Enter setup and change date and time.
Save and try.
You may have a damaged HD or boot partition and reloading the operating system will be necessary.
Reseating the HD will assure that you have a good connection and the same with the memory.
Also, if the unit has been dropped, you may have a damaged HD and may need to change it.
Posted on Sep 26, 2009
expert007
prashant LEKANAN
  • 179 Answers
SOURCE: pc wont boot up, screen stuck at packard bell
take out the cell found on r motherbord& place it after exacly 4 minutes restart it i often have this problem,, plz vote 4 me
Posted on Aug 13, 2010
Emachines screen says no bootable device insert boot disk. I have no boot disk
This error indicates that the system is not able to find a boot-able device to load the Operating System. It could be something as simple as a disconnected hard drive, or it could even be a corrupt hard drive.
You can check if the hard disk is being detected in the BIOS. The key to enter BIOS in E-machines systems are Tab, Del or F2.
If the hard disk is being detected in the BIOS, it could be a faulty hard disk. You can try booting from the recovery partition by pressing Alt+F10 when starting up the computer. If you're able to get into the Recovery Partition, you can try a recovery, but you might lose all your data. If you're not even able to get into the Recovery Partition, you'll need to get the Windows disc for installing the Operating System again.
You can refer to these links for further information:
http://h30434.www3.hp.com/t5/Notebook-Operating-Systems-and-Software/No-bootable-device-insert-boot-disc-and-press-any-key-error/td-p/151244/page/3
http://superuser.com/questions/119307/how-do-i-boot-to-the-recovery-partition-on-an-emachines-d620-notebook
GuruAid
May 05, 2014 | Computers & Internet
My emachines desktop el1333g-01w wont boot up windows the computer starts but goes into the startup repair screen and stays there
sounds like you need to re-install your os win xp w7 w8 its what we call rolling where the boot up gets to a certain point then forgets what to do so it just keeps going around and around hope that helps.
Jan 27, 2014 | E-Machines eMachines Desktop PC
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
Need recovery **** for modle# w4885 it wont boot up , nothing but black screen and cursor flashes
When you go back to boot up, and you get to the Dell screen, can you please start tapping the F8 key, that should bring you to a start up menu, where start in Safe Mode is an option. If you can get there, please go to Start, Run, and type in sfc /scannow, exactly as shown, with a space between the c and the /, then hit Enter. If you have any missing or damaged system files this should repair them.
When this has completed, please go to Start, Run, and type in MSCONFIG, then hit Enter. On the General tab, click on Diagnostic Startup, then reboot the PC. If you can get to the log in screen, then one of your startup programs is causing the problem. If not we'll have to look for something else.
Is there any kind of error message other than getting to the black screen? Is the screen completely blank or is the cursor next to something, a letter, or symbol?
Hope this helps.
Dec 04, 2010 | E-Machines eMachines Desktop PC
Computer went off while performing restore point now screen is blank
Restart the machine and press F8 continusly. You will get some options for booting, in this options select 'Last known good configuration'.
If its not working use your OS CD to boot. After booting you will get Repair option. continue with repair option.
Sep 14, 2010 | E-Machines eMachines Desktop PC
Frozen cursor
do you have a wired or wireless mouse?
Have you tried attaching a different mouse to your computer?
What is the brand name of your mouse?
Try booting your computer in Safe Mode. To do this, after turning on the computer, press F8 button several times. You will see a screen that will ask you to boot normally, boot in Safe Mode or boot in Safe Mode with Network Connections. Select Safe Mode.
See if your mouse works then.
Check back with me for further help, if needed. There are additional things you could try.
Oct 08, 2009 | E-Machines eMachines Desktop PC
Emachine d620 how to factory reset
when you restart the laptop press f2 then disable the f10 boot menu then restart your computer again after the emachines logo appaeres press f10 repaetedly until the factory defualt festore screen apeares then follow on screen directions
Jul 04, 2009 | eMachines eMD620-5133 Notebook
Operating system not found dont have a recoverry cd
do you have any external harddrives or flash drives plugged in? iv found that can sumtimes confuse sum systems?
May 18, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
64 people viewed this question
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
