Even, I have the same problem...looking for a help on internet but not finding any...if you know...please post on this site.
Thanks,
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
SOURCE: Westinghouse tv ltv46w1hd sound no picture
www.cfusion.com has the spare parts for that tv. it sounds like it is the mainboard. shouldn't be more than 150-200 to replace.
Model. Number. 32LN530B-UA
