Any ideas on what this problem is my daughter said she changes the cd out and it still does it
SOURCE: PET702 Portable DVD player 'No Disk'
try this:
Press setup on the remote
Use the arrows to navigate to Prefreneces (pref)
type 9 6 5 3
Select Region code (press down arrow to set to 0, open for all codes)
Press setup again to exit
is working :D
SOURCE: CD door will not open. Does not respond to the open close button.
the cd drive should have a tiny hole under the drawer. push a small screwdriver into the hole and it will release the drawer.
SOURCE: Nakamichi MB-2 CD Player tray sticks
It sounds like the belt that opens the try is getting bad and beginning to slip, a common problem on CD players like this. You should be able to find a replacement belt online.
SOURCE: glass door will not open and cd player will not
Glass door and cd clamper operated by same motor belt and mechanism,remove l/h sp. grille (2 screws) and this mech is easily visible.
