SOURCE: Portable DVD Player will not power up
This player should be charged up until the green light goes out to be fully charged. I usually leave them on over night.
Glenn
SOURCE: portable DVD player will not charge
I own the same DVD player. If the player runs from the AC Adapter but not from the battery (Adapter plugged into the battery) chances are the battery has worn out and it needs to be replaced. Trick is to find a battery for less than $40
SOURCE: my dynex portable dvd player 7 inch screen wont turn on!
Tries buy a new litium battery yet?Get a new adaptor charger?Tries it own website for adaptor charger or Amazon.com,Ebay.com many eclectronics parts excessorries.Tries ur local Radio Shack ask the clerk for help to buy litium battery or charger adaptors.
SOURCE: flashing red light Panasonic portable DVD-LA95
check the microswith near the hinge .
its generally located on near the back right corner of the player , on the control surface. it looks like a very small white plastic button or pip. sometimes these stick down and look like part of the player casing, when they actually are a switch. it needs to be raised , so when the lid is closed it pushes the pip down and turns the screen off. Try prising it gently free with a pin or needle.
this happened tome and i was on the verge of binning it. when i looked at the manual and it says
power light flashing slowly means screen turned off.
if the light is flashing very quickly then im afraid its knackerred and just not worth repairing.
if this is helpful to you then just drop me a line at
[email protected]
good luck
choonzy
