This is done in regards to the USB connection... which is microsoft lifecam studio webcam... which I also am having problems with...
SOURCE: Microsoft webcam installation download free
Here is the link if you are using windows XP
http://download.microsoft.com/download/e/d/0/ed04ba91-cce4-483b-9d2c-353224931303/LifeCam2.04.exe
If you are using windows Vista Click here
SOURCE: installation problem with microsoft lifecam 2.04
Try disconnecting the camera from the USB port and reinstall the software program. When the program asks you to connect the camera, then do so and not before. After the program finishes it should properly. Don't forget that you will then have to have a messenger or Skype to communicate with family and friends. Here is how to set thst up:
Normal
0
Web Camera’s have to be setup on the program they are
to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
The camera and audio should function properly. Your friends and Family will now see and
talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set
it up as follows:
When done both the Audio and Video will function properly so
you can chat and see family or friends you are connected to.
Hope this is of some help. Bud
SOURCE: microsoft drivers
SOURCE: Microsoft Lifecam / Using a different microphone
Im not sure I understood exactly the issue but the solutions are more than one ...
you may just uninstall the web cam ...and set the mic you want to use and after that reinstall the web cam ...and you have every chances to be installed and the external mic to remain in use..
or ...to use the mic from the external pink entry of the pc ...just select it from the sound driver ...options..
in your capture program you might also have the choice for which mic to use ....
in your yahoo messenger for example you have this choice on preferences /audio device....
you also may find on your control panel ...sound and audio device /audio../and for the sound recording audio device ...select the one you want...
good luck !
SOURCE: Microsoft Wired Lifecam (VX-1000) NEED A DOWNLOAD INSTALIATION
I need a free download of tha lifecam v-1000, I lost my cd. Help me please.
