Freezers Logo
r
rick slaney Posted on Mar 10, 2017
New kenmore freezer ,light comes on but dosen't start?
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
I have a Kenmore 5 cu ft freezer that won't come on. I've checked the plug in and it works fine. Where would I start looking for the problem????
If, by plug in you mean the socket, then you need to check the fuse in the power plug next.
At the very lease there should be some light on the unit that illuminate even if it does not FREEZE.
If the compressor comes on wait to see if there is any drop in temperature. then it is possible the fuse was faulty.
see below links for more information on possible causes
How to fix Kenmore chest freezer model 255 19502010
Kenmore 5 cu ft 142 liter Chest Freezer 14512 Page 11 Recent Questions...
Compressor will not come on
Check that the freezer has power. After that make sure the thermostat is turned down low. If it still isn't starting, listen for any clicks like its trying to start. If no clicks, replace the start capacitor or thermostat. If there's clicks like its trying to start, try a hard start kit for your freezer, or you might just need a new compressor
In OF mode-wont come on - is new
I have a similar freezer under the Kenmore brand and experienced the same problem. Try raising the temp setting to +10 degrees. Unit should then start up again.
Freezer alarm and signal light comes on daily
The beeping and light indicates the need for a new battery (9v)
14.1 upright Kenmore freezer was unplugged to clean after hurricane. We moved freezer to new location, never turning it on its side...plugged in and light works but freezer is not cooling. There are no...
Check to see if there is a reset on the compressor or close to it. Turn your control knobs up and down and see if you hear a "click". You might cause it to engage at that point. Let me know how this does.
1helpful
Kenmore Upright Freezer Works Sometime
try a new start relay and overload kit specifically for the make and model freezer you are working on. if compressor can be seen ,the numbers on it can be used to get correct oem start cap, relay ,and overload. if your unit is having starting problems that will usually fix it. if however, the stat is failing to bring it on a new stat is called for. but it sounds like it is having starting problems since you said it was off a long while then still struggled on the overload to start then finally did. if the new start components don't work then new freezer time. compressor replacement is to expensive anymore. good luck
Where do you see the water coming from ?
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
