Computers & Internet Logo
l
leo harty Posted on Mar 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need help to have time display change from pst to cst
Rick Hickerson
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 119 Answers
  • Posted on Sep 11, 2017
Rick Hickerson
Expert
Level 2:
New Friend:
Greenhorn:
Answers
119
Questions
0
Helped
10272
Points
254
Double click on the time and subtract 1 hour.
Clock face does not show DST. When clock is set to correct time, it turns back one hour at midnight.
DST start and stop was changed a few years back. If you clock has embedded code with the old start and stop, the only way to fix it is to turn off automatic DST. Not sure what clock you are using however it appears to picking up the current GMT time. Another cause is if you have a time zone setting, CST, EST, PST etc.
1helpful
2answers
How do I change from Fahrenheit to celcius? Model # 00621cadia2
You can download the manual here http://www.acurite.com/kbase/00621_Weather_Station.html
Set the Time, Date & Units Press the "SET" button, located on the back of the display unit, to enter SET MODE. Once in set mode, the preference you are currently setting will blink on the display.
To adjust the currently selected (flashing) item, press and release the "up" or "down" buttons (press and HOLD to fast adjust).
To save your adjustments, press and release the "SET" button again to adjust the next preference. The preference set order is as follows:
TIME ZONE ( PST MST CST EST AST HAST AKST) DST (Daylight Saving Time ON or OFF)*
CLOCK HOUR
CLOCK MINUTE
CALENDAR MONTH
CALENDAR DATE
CALENDAR YEAR
TEMPERATURE SCALE ( ?F or ?C) BAROMETRIC PRESSURE SCALE (inHg or hPa)
*If you live in an area that observes DST, DST should be set to ON, even if it is not currently Daylight Saving Time.
You will automatically exit SET MODE if no buttons are pressed for 30 seconds. Enter setup mode at any time by pressing the "SET" button.
How to set
Hello
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner
1helpful
Cant fix the time zone
Successful reception of the time-synchronization radio signal is indicated by a radio waves icon to the right of seconds in the upper section of the display. After synchronization occurs, you can select your continental U.S. time zone (EST, CST, MST, or PST) by means of a switch on the back of the clock.
1helpful
I am getting EST time. I live in MST. How do I reset the time ?
Successful reception of the time-synchronization radio2_bing.gif signal is indicated by a radio waves icon to the right of seconds in the upper section of the display. After synchronization occurs, you can select your continental U.S. time zone (EST, CST, MST, or PST) by means of a switch on the back of the clock.
I have a battery operated satelite clock that deplays the time, day, temperature, alarm, and world time. I lost the instructions on how to operate. Please help0!
2answers
Setting the time zone
I actually have the same problem with an older model Brookstone weather station with remote temperature gauge. The time/date settings do not allow you to set time zone and eventually the clock syncs to PST.... ANY HELP HERE?
Digital atomic clock radio
Hi. There should be a switch on top of the radio that allows you to select the time zone. It is just behind the snooze bar and labeled PST-MST-CST-EST. Try that.
Top Time Computers & Internet Experts
Thomas Perkins
Thomas Perkins
NOEL
NOEL
Are you a Time Computer and Internet Expert? Answer questions, earn points and help others
