How do I get the driver for this external drive
SOURCE: SimpleTech PininFarina external hard drive - site to download drivers
the hard drive you have is plug n play.
if windows does not recognize it, you may have to uninstall the hard drive.
right click your computer. click properties.
click on the "Hardware" tab. Click on "Device Manager".
open the category of "Disk Drives".
If you see your drive with a yellow exclamation point or a red "X", continue. If it does not, either it was dropped or its a faulty drive.
Right click your drive and click "Unistall". Click OK.
Now, unplug the drive and plug it in again.
it will install by itself.
Go to my computer and check that its there. If its not, you may have a bad drive. either send it for a new one (if still in warranty) or replace it.
SOURCE: No Write permission when attaching Simpletech external drive to Mac OS 10
simple just format it for PC first then it should work for both
if you format it for MAC first it will not work on the PC
simple
PC are horrible for accessing files
mac's are more user friendly
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
SOURCE: computer does not recognize simpletech
I have a simpletech external drive that was working, but after i disconnect it unproperlly, i was getting the message <usb not recongnize>. I called simpletech, but customer service is ****, and anyway the drive inside is a hitahi, i have another simpletech and the drive inside is a western digital, whatever...
They told be to go to best buy to make a recover, so i called and they told me it s 250$, and if they cant do it, they will send it to a labotory witch cost 1700$, crazy ******* hein?
I red about getting drivers, putting the hdd in a fridge and much more stupid thing, BUT THE SOLUTION IS SIMPLE, OPEN THE CASE, UNDER THE ALLUMINIUM STICKER THERE IS 2 SCREWS, REMOVE THEM, OPEN THE CASE, TAKE THE HDD INSIDE OUT AND REMOVE THE ADAPTER CONNECTED TO THE HDD(WHERE YOU CONNECT THE USB CABLE) CAUSE THIS IS THE PART CAUSING THE PROBLEM, THE HARD DRIVE IS OK AND YOU DIDN T LOOSE NOTHING. So now what you can do is just buy a new case for laptop hard drive (with a new usb adapter included), or buy another simpleshit hdd and switch the adapter part or just buy an adapter to make your hdd an usb hdd and Voila, and after that i suggest you buy yourself a better hdd than simpleShit and make a new backup.
SOURCE: SimpleTech (re)drive 1.0 tb - how can I get a
Try going to their web site HERE. I could not decide which of their products would suit you best.
SOURCE: looking for software/driver download for
SimpleTech hard drives do not require a driver to work. You might try a different cable or check it on another computer. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
