Hi Bob, did you solve the conundrum?
Have the same problem with the white plastic cover for T49706.
https://forums.watchuseek.com/f2/help-required-timex-e-tide-watch-t49706-battery-change-4943661.html
SOURCE: Can't get the back plate of a Timex Indiglo WR30M watch back on
It is either a screw on case back or a "snap-on. I suspect that it is the latter since you don't mention that you used a tool to unscrew the case back. So getting the back on sometimes is very difficult. I have a special tool for that to apply even pressue and the necessary force and does not put pressure on the crystal. You have to be careful to not damage the crystal. If you don't get it done, then suggest you take it to a shop that has the right tool. If you have very strong thumbs you might get it done.
SOURCE: REMOVE BACK COVER
If caseback is without grooves, it is snap on caseback and you have to insert openers blade under the lip and pry up. Lip is the tiny gap between the case and caseback.
If you have groves in caseback, it is screwdown caseback and you will need special opening tool. Insert the blades in to the grooves and unscrew the caseback.
You can find this tool on eBay.
Rate, please.
SOURCE: timex watch cover replacment
Align the caseback exactly as it was before you opened it. Make sure thet the groove for stem is in correct position. Lay the napkin on the flat table surface, put the watch on it (dial down) and using both hands and your body weight push the caseback down back in place. Remember: the side of the caseback wich first came out must be last pushed in.
Do not use very soft napkin (towel) as this can brake the glass under the pressure.
If all above described DO NOT work, then there is not enough power in your hands or not enough weight in your body and you will need watchmakers help (he/she will be using special watch press to close the watch).
P.S. Do not get upset if you can not close it; I'm very expierenced watchmaker and very often came across the watches wich I was not able to close without the watch press (even my arms are quite strong and the weight is 95kg).
Do not forget to rate, please.
SOURCE: cannot re-attach timex watch back
good morning ! you need a pressing tools device to put back the case back of you timex watch! thanks ! god bless !.....
SOURCE: watch battery replacement
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
