Dishwashers Logo
donny littlejohn Posted on Mar 07, 2017
Samsung dishwasher won't come on the lock light is on
Jere Quinn Jr
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Feb 08, 2019
Jere Quinn Jr
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
1087
Points
Make sure disposal is working. Also you might have the child lock on.
My Samsung Dishwasher, model DMR78AH5 will not run. The heavy, delicate, quick and smart lights are permanently on. I cut off the breaker for one minute but that did nothing.
How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
www.partselect.com/Repair/Dishwasher/Will-Not-Start/
If your dishwasher won't start the problem could be the door latch or door latch ... On manual timer models the timer is used to supply power to the pump motor, ...Missing: samsung ‎dmr78ah5
Samsung Dishwasher Won't Start - Model DMR57LFS ...
www.repairclinic.com/...Dishwasher/...-/Samsung-Dishwasher-won-t-start...
The door latch ensures that the dishwasher door latches shut. If the door does notlatch properly, the door switch might prevent the dishwasher from running.
What to Do When the Dishwasher Won't Start - YouTube
? 5:43
https://www.youtube.com/watch?v=L-bMqVb9kX0
Aug 15, 2013 - Uploaded by doityourselfstan
The problem could simply be a blown thermal fuse inside the control panel. ... Maytag Dishwasher Repair ...
2answers
I have 3blinking lights on a Samsung dishwasher DW9733LRABB/AA the normal,heavy, and smart auto
Dishwasher Heavy Error Code Repair Samsung - YouTube
? 2:24
https://www.youtube.com/watch?v=uLoj9TpqVRM
Aug 14, 2014 - Uploaded by JoeBrownToolGuy
Dishwasher error code "Heavy" flashing light. Samsung Model DMT400. Video shows what you need to do ...
How do i unlock my samsung dishwasher
It depends on the model. For example, IF you have a DMT400 series, although the light ABOVE the Low-Rinse-Aid light is lit, you press and hold the SANITIZE light for 3 to 5 seconds. Other models are different, but if you look closely at your dishwasher control console, you should see some small print that will say something like "Child lock/unlock, (Hold 3 sec)".
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Door won't lock
If your dishwasher door won't lock, it could be a problem with the latch adjustment or the door seal. Some latches are designed to be adjustable, and yours may be set too tightly. Look at the owner's manual for specific instructions or follow these basic steps for adjusting the latch:
1. Spray WD-40 or other lubricant onto the latch.
2. Slowly open and close the door several times, noticing whether the door hits the strike plate (the metal plate on the top of the dishwasher frame). Use a hammer to lightly tap the strike plate to move it as needed.
3. If possible, adjust the depth of your latch by unscrewing the latch assembly using a screwdriver and reseating it. Work with the adjustment until it latches correctly.
Note: If your latch is permanently fixed, have a qualified professional address the problem.
The door seal-also called a gasket-can also cause problems if you have a brand new dishwasher or door seal. The good news is that the door seal will mold to the door's shape over the first week or so. Operating your dishwasher with the highest level of heat will help this process happen more quickly. Because the material is pliable, and because heat will soften it, it will seal to the door more securely after those first few loads.
On the flip side, an old door seal can also keep your door from closing correctly. Check the seal for signs of warping or damage. If the seal needs replacing, arrange for service, or consider doing it yourself. In most models, it's a relatively easy DIY project. See Dishwasher gasket replacement for step-by-step instructions.
For more troubleshooting steps, see Dishwasher door repair. I hope this helps!
My dishwasher won't start at all
There could a number of reasons why it won't start but start with the locking mechanism first. Make sure the locking mechanism is in the "Locked" position. It will be the lever at the top of the door. If that isn't the problem try describing everything you have tried and post your question again.
I have a maytag dishwasher theres a 3 second button to hold in order for it to start but it won't start it's stuck on 3 second lite
hold the heated dry button for till that light goes out. then try to start. it is a child lock that is on
Unit just quit. won't start up. press start button and won't even light up
please provide the model number of the Samsung dishwasher.
if none of the lights light up, then a fuse might be blown somewhere. If the problem is the start buttion does not start the dishwasher , then the door latch switch could be faulty.
1helpful
My dishwasher won"t wash. Help me, PLEASE???
Try pushing and holding the "Air Dry" button for at least 4 seconds. This should turn the control lock off.
2helpful
3answers
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Top Samsung Dishwashers Experts
vince
Daniel Blask
Daniel Blask
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
