Sewing Machines Logo
A
Ann Thomas Posted on Mar 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set the bobbin case in Viking Diamond machine
Sewingirl
Level 2:
Sergeant:
  • Sewing Machines Expert 248 Answers
  • Posted on Mar 12, 2017
Sewingirl
Level 2:
Sergeant:
Answers
248
Questions
0
Helped
42367
Points
601
Hello Ann Thomas
Refer to the Designer Diamond manual section 10:2, page 124. You can download the manual for free here: https://www.manualslib.com/manual/614325/Viking-Designer-Diamond.html?page=124#manual
And here is an excellent youtube video: https://www.youtube.com/watch?v=kQhTTpbzrlg
Please let me know how it goes for you.
Happy Stitching
Sewingirl/
5 Related Answers
Anonymous
  • Posted on Jun 23, 2008
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Anonymous
  • 87 Answers
  • Posted on Mar 19, 2009
SOURCE: Bobbin tension on Viking 350 Sewing Machine
Viking bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Anonymous
  • 111 Answers
  • Posted on Jun 11, 2009
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
deborahcha
  • 371 Answers
  • Posted on Sep 24, 2009
SOURCE: husqvarna sewing machine - viking 400
Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
deborahcha
  • 371 Answers
  • Posted on Feb 13, 2010
SOURCE: The bobbin thread on my Viking Designer 1 is too tight
In most cases, this is caused by loose threads and fluff being in the upper tension unit rather than a problem with the bobbin. There is a screw on the bobbin case that losens and tightens the resistence. However, it can easily come out and then you have a mess.
Try this to check the bobbin thread tension -
Take the bobbin case holder out of the machine. Use a bobbin that is about half full and use standard 50 wt sewing thread.
Take your needle plate (the metal plate over the feed dogs that has markings showing stitch width under the presser foot).
Thread the bobbin thread in the bobbin case, holding the case so that the thread is through the tension spring as though it is in the machine, tied the end of the tread to the needle plate and have it hang below the the bobbin case.
If the needle plate immediately drops to the floor, unwinding the bobbin, the bobbin tension is too loose. If you jiggle the bobbin case slightly up and down and the needle plate moves slightly down, it is just right. If it does not move at all it is too tight. The resistence should be 14g which is the weight of the needle plate.
The upper tension unit, look straight down from the tension unit and you should see some metal disks which the upper thread rides through when threaded. Take your small cleaning brush and brush out any loose threads/fluff there. Look down the left side of the tension unit to make sure there is none hiding.
When you tighten the upper tension unit by pushing the tension buttons on the screen, do you hear the tension disks tightening? If not, it may be the pc board or the tension unit itself that will have to be replaced.
Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck
I have a viking 990s that I bought from school surplus. It came with nothing but one foot. I bought a bobbin case for it but when I put it in, it does not click..or seat... what am I doing wrong?
Hmm, did they represent the machine as working? My first thought is that perhaps you do not have the correct bobbin case for your machine. The other is that the machine is defective. Also, be sure you are using the correct bobbin. Some bobbins will appear to fit but, if only a millimeter off, may not work. It could be the bobbin is too wide and preventing the bobbin case from seating completely. Also, if any thread extends outside the bobbin, it may not work well.
https://www.sewingpartsonline.com/viking-990-sewing-machine-parts.aspx
Designer diamond viking how do we get to machine settings
Can't help without knowing the make/model machine.
Search for:
Make Model manual
How set bobbin case in Viking Diamond?
Hello Ann Thomas
And here is an excellent youtube video:https://www.youtube.com/watch?v=kQhTTpbzrlgPlease let me know how it goes for you.
Happy Stitching
Sewingirl/
My viking emerald 118 machine just started breaking needles and the bobbin thread will not hold. YOu can pull the bobbin stitch out by pulling the thread.
Check the upper tension by lowering the presser foot and pulling on the thread through the needle. You should feel resistance. If not, take a stiff brush and clean out the tension disks/dials removing any loose threads or lint. If upper tension is ok, check bobbin tension by pulling thread through needle plate opening. You should feel resistance. If not, remove bobbin case and brush any loose threads or lint from the case, especially in the tension spring where the thread is snapped into place. You may need to use a sharp needle to dig in between the spring but be careful that you don't damage it.
Remove thread message in husqvarna viking sapphire 870 quilt
I had this same problem, on my Designer Diamond. I blew it out with an air can and that didn't work, but then I decided to turn it off, then back on and start sewing a line in reverse. That seemed to fix it. My machine is working fine now.
Viking 1: where is the bobbin control, my bobbin is loose...
The bobbin spool is loose, the bobbin case is loose or the bobbin stitches are loose??????
If it is the last one - thread the machine with the presser foot up and see if this resolves the issue.
2helpful
3helpful
2answers
Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
4answers
Missing bobbin case and bobbins Husqvarna 4000-serie sewing machine
ask where Husquvana machines are sold. google dealers if you don't know.
Sewing machine husqvarna 3610 bobbin case spring has broken and the bobbin will not stay in the machine. How do I repair the spring?
You probably will need to replace the bobbin case. It is probably only available from Husqvarna Viking. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
