Question about Tomtom GO 910 GPS Receiver
Restore to factory setting
Restore my tomtom 520 back to how it was when i first opened my box
    Brigadier General:
  • 4,090 Answers
N rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? restore to factory setting - ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Posted on Jul 26, 2009
6ya staff
SOURCE:
To many unwanted files
Remember to back-up all off your important documents, files, photos etc to a backup external hard drive, USB stick etc.
you can use the restore function of Acer Recovery management by following the procedure below-
Step 1:
Click “Start” menu.
Step 2:
Click “Programs.”
Step 3:
Click “Acer Recovery Management.”
Step 4:
Click the “Restore” button on the bottom of the dialog box that opens.
Step 5:
Click “Restore System to Factory Default.”
Step 6:
Click “Yes” in the warning dialog box which asks if you wish to continue the recovery process.
Step 7:
Click “Start” to restore the computer to the default factory settings.
//javaftper
Aug 01, 2010 | Acer Aspire 5315 Notebook
I downloaded the US-Canada map update and now i turn my TomTom on and it says i cant us that map and now i cant even use the device is there someway i can restore the device back to default?
You could try reseting the device
1) Turn the device off.
2) Press the Reset button located on the bottom of the device (you'll need a paperclip to do this).
3) Turn it back on. See if it works now.
Or...
1) Do you have Tom Tom Home set up on your computer?
2) Did you ever make a backup?
If so, now is the time to restore from backup.
To restore factory settings:
1) Turn on Show All Menu Items in the Preferences menu.
2) Tap the Reset Factory Settings button (it's on the last screen of the Preferences menu).
Best of luck to you.
Nov 24, 2009 | Tomtom One XL GPS Receiver
How do I rreinstall my maps and indeed my operating system on my tomtom 522 go after unintentionally formatting it
Did you install and use TomTom Home program on your PC? Did you backup you 520? If you did you can restore the contents. If not you can reinstall the Navigator Application from TomTom by using update in the TTHome program. Unfortunately It will not give you a map, you will have to ask TomTom if they will help you or if not buy a new copy. If the unit is fairly new you are entitled to an update but that may have passed. If you want to spend some time it is possible to download a pirate copy but it needs to be cracked and files updated. A good site is the IPMART forum
Nov 22, 2009 | Tomtom GO 520 GPS Receiver
I have the tomtom go 520,i have changed my computer and have lost my set up disc,can i download the drivers so i can update my unit
Tomtom uses the generic usb drivers. You can download tomtom home from the download section of the tomtom website
Jul 11, 2009 | Tomtom GO 520/720 Remote Control
Lost activatoin code for 520 tomtom no help
Go to this site for your map problem. http://www.gpsunderground.com/forums/forumdisplay.php?f=38
Apr 17, 2009 | Tomtom GO 520 GPS Receiver
Reset
Tap "Reset factory settings" button to restore the factory settings to your TomTom XL. All your settings, including Favourites, your Home location, warnings for POIs and any Itineraries you have created are deleted.
Tap "Set Clock" button to select the type of clock that is shown and set the time.
manual download
go to tomtom website ----> support scroll down at the right hand side click Find downloads
hope this help
20/Apr/09
Apr 02, 2009 | Tomtom XL 330 Car GPS Receiver
My device tom tom 520t keeps switching itself off every 3-4 minutes unless i press cancel on the screen i've tried to reset factory settings but no change
Your set needs to be opened, and have the following checked, regulation semi conductors of the power supply. or resistors changing values at the supply, or capacitors not filtering ripples. thanks
Mar 18, 2009 | Tomtom GO 520 GPS Receiver
Tom tom home does not see my tom tom go 520
Hi canal_boat_m
Try this solution:
STEP 1 Un-install Tom Tom Home from your PC
STEP 2 Click on the link below:
http://tomtom.com/lib/img/cs/S4S/files/RemoveRegEntries_TTGOv1.exe
This will download a little removal program for the Tom Tom Home program.
A Black window will appear briefly then close.
• Make sure that you have got Administrator rights on the PC. Otherwise you may not be allowed to connect new hardware (especially the case when using office computers)
• Reboot your PC
STEP 3 Visit Tom Tom website and download the current new version of Tom Tom Home and install it to your PC
STEP 4 Connect the TomTom
• Make sure the device is fully charged before connecting it to the computer. Ideally a mininum of 4 hours charge.
• Reset the device using a paper clip (see http://www.tomtom.com/6965). When resetting, keep the reset button pushed in for at least 20 seconds, but DO NOT turn the device back on just yet.
• Ensure that your TomTom has power connected to it. There should be a green light on the TomTom unit. If your device came with a Home Charger, please make sure that is plugged in to the TomTom also.
Your Tom Tom should ask you to 'Connect to Computer' if it does tap YES.
SOLUTION:
Your unit should now be recognized by your PC.
IF IT DOESN'T then follow the instructions below:
1. Connect your unit to your PC;
2. Copy two folders to your PC (namely 'Raster' and the one which holds all your maps - probably called 'United Kingdom and Eire';
3. Using Windows Utility, right click on the Tom Tom drive unit and select Fomat;
4. Switch off the unit and soft-reset it with a paper clip (but hold it in for at least 20 mins) and then re-connect it and power it up;
5. Tom Tom Home should now detect the unit and your unit should ask you to 'Connect to Computer' so tap YES;
6. Tom Tom Home will now say your device needs updating - and if you apply all the changes it will restore it to Factory Finished!
7. Then all's needed is to replace the two folders you backed up and any other items like mp3's and sounds, pics, etc.
Feb 27, 2009 | Tomtom GO 520 GPS Receiver
Change time on tomtom GO 520
I had the same problem until my wife quickly figured it out.Touch the main part of the screen and then touch change preferences.Hit the forward arrow several times {4 on mine}then you will see "set clock".I'm not sure if i have a 520 ,but it is a tom-tom.
Jan 17, 2009 | Tomtom GO 520 GPS Receiver
No maps found??
my tom tom 510 would start, i have charge the tomtom with green light on, but tomtom is not coming up
Feb 09, 2008 | Tomtom GO 510 GPS Receiver
Tomtom GO 910 GPS Receiver Logo
5,281 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
