Question about McCulloch Garden
Need oil pump for A McCULLOCH CHAIN SAW MODEL #MS 40A OLD PUMP has the numbers pa6-gf30 on it.
    Top Expert:
  • McCulloch Master
  • 2,931 Answers
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
need oil pump for A McCULLOCH CHAIN SAW MODEL #MS  - helpful-rx44h4hsqebyqg3voy0wii3n-2-0_5.png
Posted on Mar 11, 2018
5 Suggested Answers
6ya staff
SOURCE:
Robert Sabino
  • 142 Answers
SOURCE: no oil to McCulloch saw
If it was working a week ago, look at the saw
It way need cleaned, even though the discharge hole looks clean
happend with mine(1360) ...drained oil and used degreaser over and down the hole, dumped it all out, then refilled,and it seemed to work just fine after that
Posted on Jul 07, 2009
scottspaldng
  • 10 Answers
SOURCE: What is the oil/gas mix
You want to use a 40:1 ratio. For 1 gallon of gas use 3.2 oz of oil.
Posted on Mar 01, 2011
Andrew White
  • 2239 Answers
SOURCE: i have a Mcculloch electric
This is a full strip, and split side covers to get to the pump, this may well be a job for the local repair agent, having been apart it should then be PAT tested to ensure the double insulation it still good.
Posted on Mar 21, 2011
Mike Walker
  • 54 Answers
SOURCE: McCulloch 14" chain saw Model CS 38 EM It quit
Most often there is a dust-oil clog in the bottom of the bar slot which closes an oil passage between the bar slot and the hole drilled half way through the side of the bar. This provides a passage between the thin shim plate with the two bar bolt holes beside the bar and through to the oil tank or pump output. You can remove the bar and chain and punch out the blockage in the bar with a paper clip if the chain is removed. Make sure the wire can be pushed from the bar slot right through the side hole in the bar. A gravity feed chainsaw should leak right out into the slot of the shim plate, a button pumper should squirt out there with the bar removed. With a button pumper you may have a tiny check valve in the line or the push button to take apart, replace the spring or unstick the ball inside the check valve. This is why they went to the gravity feed oil system which just leaks in there and gets picked up by the bottom of the links as the chain races past the passage between the bar side hole and the chain slot.
Posted on Mar 24, 2011
Testimonial: "I checked as you suggested and I removed the pump from the crank shaft and the plastic gear is stripped. Now I can not find a pump. Thanks Jim"
How do I change disk/blade in my Makita PA6 - GF 30.
Thats a material code of Polyamide many products are based on this PA6-GF30 code. like to see here for example
Polyamide PA6 GF30 Jacob moeren metrisch WKK Nederland
Search on the pictures in Google for the right saw model
Feb 05, 2017 | Makita Saws
Mar 23, 2011 | McCulloch Garden
I have a Mcculloch electric chain saw model 235 for which is not pumping oil onto the chain. Can you please advise where I can purchase a new oil pump Regards Darryl.
Mar 20, 2011 | McCulloch 14" Electric Chain Saw Mcc1514
What oil does it take
You provide no model number so my answer is limited. Use "Bar and Chain" oil available at most home centers and hardware stores.
You can likely find an OM for your saw here: If the entire model does not work try just the numbers then choose from the list provided.
McCulloch International
http://www.mcculloch.biz/int/
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 15, 2010 | McCulloch 14" Electric Chain Saw Mcc1514
Chain bar not getting oiled
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 and McCulloch it is most likely a defective hose or oil pump (see IPL).
You provide no model number, try for IPL here :
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 21, 2010 | McCulloch Garden
Chain oil pump does not work when pumped. Eager ****** MAC 100 series
Your Eager Beâver model number is 600016. There are many prefixes and suffixes. The one below I used when repairing a similar problem with my Mac 110 (earlier version of your saw). Both the automatic and manual oilers work now.
I get the best results for new McCulloch parts here:
This is a little complicated so I am going in small steps.
M & D Mower
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “18-600016-27”
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
See “General Assembly” print
Item 33; pn 85557; Oiler body; most likely failure, on bottom of Item 31
Item 31; pn 217755; manual oiler piston; It pulls through the top of the tank. I ordered a new one but got Item 36, they were the same pn, I complained, seems they fixed it.
See “Powerhead Assembly” print
Item 07; pn 219989; oil pump assembly
Item 04; pn 217168; pump/bar pad connector (hose)
Item 05; pn 217167; pump/oil tank connector (hose) The new one was to long, I used the old hose. I have an earlier model.
Item 17; pn 110653; O-ring
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 06, 2010 | McCulloch Garden
Chain not getting oil
Extremely difficult! If the oil pump or worm gear is defective it may be the most difficult saw to repair. This is the only saw I have seen with the oiler mounted behind the fly wheel.
Your basic model number is 600035. There are 11-, 21-, and 22- prefixes used with 600035s. There are also a ton of suffixes with the 600035s. I think the suffix is on your saw immediately after the basic model number somewhere (usually on bottom of older Macs along with the serial number. The dash of the serial on older Macs is the prefix). I must defer to you to find your exact IPL, here:
McCulloch IPLs
I chose this one as an example "22-600035-58" for an IPL
http://www.ordertree.com/modelinfo/MCC/22-600035-58-Mac-3516-IPL-211229-01/139.22-600035-58-Mac-3516-IPL-211229-01.1.59.1.html
The "Powerhead Assembly" lists an oil pump (1) and a worm gear (10). These are the most common failure on most saws but Macs have many more hoses than most. There are oiler components on at least 2 different details. It appears the oil pump is on the starter side of the engine. and you may need to remove the fly wheel for access. I would examine every connection and perhaps try the "Kit Gear/Plunger Assembly" before trying to access the oil pump and gear.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
You can reply below with any questions. I hope you found this most helpful. Good Luck
Lou
If you opt to remove the fly wheel PLEASE reply to me first. I can probably save you a couple of headaches and may prevent component breakage.
Feb 01, 2010 | McCulloch Garden
Mcculloch eager ****** no oil going to chain
The oiler pumps on Macs are the usual suspect, try this:
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
Build an IPL number like this:
McCulloch Manual
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
If you can not find parts please repost with the IPL number and I will share my secret Mac parts source.
Lou
Dec 03, 2009 | Drills
No oil to McCulloch saw
Jul 06, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Garden Logo
83 people viewed this question
Top McCulloch Garden Experts
roeb
John Trevino
Sheldon Dedek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
