Have you checked to see if the batteries are fresh in the remote? Sometimes the remote will act up and not lock or start the car when you want it to. If the batteries are fresh I would suggest seeing about getting a new remote or take the remote in to the dealership and see what they can do about it. There should be a troubleshoot guide in the car for this or you could probably find out more online. http://www.autodream.ca/shop/c/80/car-starter-calgary http://www.autodream.ca/shop/c/80/car-starter-calgary
spray WD-40 on the hood pin switch and the door latch, not unless your car is a ford, it could be the R.A.P system shutting down, diodes may need to be installed
I Sounds like the factory alarm has not been disabled or bypassed properly yet. The car thinks that someone somehow got into the car while it was locked and tried to start it. Had the same issue on my car and had to unlock then lock it again to start it.
How do you reset the remote, alarm. I have a scytek two way security alarm, remote start. I can lock and unlock my vehicle, however the remote start and alarm won't work. When I press the middle button to have the car start it just beeps, and when I lock my car it just locks it doesn't beep to let me know the alarm is on.
Please advise, do I need another alarm, or just reset it.
yes, most gm cars/trucks made after 1988, and just about everything after the early nineties requires a bypass. DEI has a very easy to install and use bypass for these vehicles, the 555L is perfect. If you cannot locate this discontinued unit, I have some available. Respond to this solution with your email, thanks
