Camera a bit old, at start I uploaded some disc I think. `Always uploaded fine until this update. Now it shows my camera within iPhotos, with the pictures on it but will not move them to a album etc
SOURCE: Fuji Finepix F700
I had the same problem with my F700,recently I found a website that helped me a lot.Apparently the problem is the CCD. read this website and the problem will be solved. http://209.85.165.104/search?q=cache:6MDTb5yCWCIJ:forums.photographyreview.com/showthread.php%3Ft%3D14939+recall+for+fujifilm+f700&hl=en&ct=clnk&cd=5 Good Luck!!!
SOURCE: can't download pictures from camera
perhaps your Fuji download program is corrupted, or your cable has been broken. Most computers now have a direct plug-in for your memory card, as well as plenty of built-in programs to download your pictures. I like the Vista Photo Gallery (come to think of it, it is the ONLY thing I like about Vista. At any rate, unplug your xD chip from the battery compartment (you can just pull it out, or push it and it pops up), (and close the battery compartment, or you will have to reset the date and time), plug it into your computer, and wait for a bunch of programs to pop up eager to download your photos. If that doesn't work, you may have a bad chip--but if you had a bad chip, you couldn't view your pictures on your camera. If you have XP, you should be able to see the xD as a new drive if you plug it in--not sure which programs will pop up, but you may be able to move the pix just like any files from one drive to another. Good luck. Incidentally, if you need a new cable, internet charges range from 3 to $25.
SOURCE: I have the fuji finepix
Take out the Camera software.
Then restart the computer
Let Windows do it all by its self
SOURCE: Help!!!i lost the software that came with my fuji fine pix S6500
hi.
here's the direct link for the S6500fd photoshop plugin download from adobe. photoshop should open raw after you've installed this:
http://download.adobe.com/pub/adobe/photoshop/cameraraw/mac/3.x/DNG_Camera_Raw_3_7.dmg
Here's the adobe downloads centre link in case you need to check up on everything & the installation instructions.
http://www.adobe.com/support/downloads/thankyou.jsp?
Cheers Andy.
SOURCE: fuji A850 will not power up
I had the same problem, same camera. So I checked to see if other digital cameras had the same problem, and some did. Seems to be with the batteries. I took out my memory card, and reinstalled the batteries that came with my camera, I've only had it a few days. Turned it on and it worked, so I took a pic, and then turned it back off and reinstalled the memory card, and made sure it was formatted. Turned the camera back on and it worked, and took another pic with no problems. The batteries I have right now are Panasonic Alkaline for Digital. They seem to be a heavier battery, because the cheaper ones are lighter and didn't work. So I say try that brand or make sure the batteries are for digital purposes. Hope this helps.
