LG 55LN5700 55" Smart LED TV 1920x1080, 120 Hz, HDTV, 3D Logo
K
Ken Gilbraith Posted on Mar 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG 55LN5700 led tv.. has black screen no pic but does have sound. I replaced the led driver/power supply board & tv still has no back lights and no pic. I can see the pic with a flashlight test.
shaun taylor
Level 3:
  • LG Master 1,527 Answers
  • Posted on Mar 05, 2017
shaun taylor
LG Master
Level 3:
Answers
1527
Questions
0
Helped
338025
Points
3957
Hi the led or leds has shorted in the panel, thanks
shaun
  • Ken Gilbraith
    Ken Gilbraith Mar 05, 2017
    Thanks for the help!!!!! :)
LG 55LN5700 LED TV. Screen went black, audio works. Flashlight test, able to see pic moving. Replaced LED strips & pwr board. Try turn on, LEDs blink 1x and red light flashes 3x. Let it sit 8hr
Replace the jack wires going to the LED strips. Or look for the one bad jack wire going to the LED's and fix it. Use a volt meter on ohms to find the bad wire.
2answers
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
1helpful
Have a LG 55LN5700 tv with no picture but has sound. Flashlight test shows image on screen. When turning on LG image flashes on screen then all is black. What do you think the problem is?
55" LG LED television screen went dark
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
LED TV screen has flickered momentarily and faded to black. I have sound and power buttons light up. LED solid black, not lit. Bad LED Driver board?
My LG 47LN5400-UA flatscreen has a black screen, everything works fine except black screen, when I shine flashlight on screen I can see full color picture, I have replaced the power supply/LED board.
http://electro-medical.blogspot.com/
LG 50" tv pic went black but it still has sound.
1helpful
LG 32LB530A Tv sound ok faint picture Led backlid off
Back light led driver or the led array is faulty. check and confirm the voltage to the led back light from the power supply. normally 35V to 100V according to the brand and model of the tv. Check the voltage if the voltage is somewhere around the above mentioned voltage the then the tv have problem with the led array behind the screen . If the voltage is missing then the led driver is faulty. Normally the led drivers is found integrated to the power supply board. If so then you have to replace the power supply board as a whole.
www.electro-medical.blogspot.com
I have an LG 55LN5700 the video goes away after 15-20 minutes while the audio still working Please Help!
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Model 55LN5700. Turn on, LG logo pops up, screen goes black. What's wrong?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
