Rv air conditioning
You may have to remove your filter & look for a model # of your unit, so we can pinpoint your wiring to the thermostat. Usually the terminals on the thermostats are labeled -RC-RH- etc, and you simply move old to new of the same. A lot of times some manufacturers will use phone cable form AC unit to thermostat, and mix up the colors, that's the reason for going to the AC and see what color is used from there. It could be red from control box, connected to green wire to thermostat for example. Thats where you note it and wire accordingly.(terminal calling for red wire, would now be green) If your stumped, get back to us with that model#.
