My cell phone. I put a fingerprint lock screen app on here and now it won't let me do anything it will not scan my print it will not let me do my backup password or anything how do I remove app from my phone using my tablet this please
SOURCE: Forgot password on my mobile phone
Try typing #pwd# and then "send. It will reset your password to the the last 4 digits of your phone number. Then you can reset your password back to what ever one you can remember.
SOURCE: My cell phone is locked.
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
SOURCE: fingerprint reader activated and has me locked out after reboot
hi
here are some steps to disable finger print reader..
The easiest way to disable the Microsoft Fingerprint Reader’s default operation is to rename the highest level program file.
To do this, the DPAgnt.exe program must first be terminated.
Step 1: Press Control-Alt-Delete, so the Windows Task Manager comes up.
Step 2: From the Windows Task Manager, click on the “Processes” tab.
Step 3: Find and highlight DPAgnt.exe by clicking on it.
Step 4: Right click on DPAgnt.exe, and click on the “End Process” menu, as seen below.
Next,
you have to rename the DPAgnt.exe program so it won’t be loaded at boot
up time. The Microsoft Fingerprint Reader’s program and driver files
are located in the “C:\Program Files\DigitalPersona\Bin” folder on a
Windows XP Home or Pro hard disk.
Step 5: Click on the “My Computer” icon on your desktop.
Step 6: Type into the “Address” bar input area, and enter “c:\Program Files\DigitalPersona\Bin”
and hit return.
Step 7: Single click on DPAgnt.exe
Step 8: Right click on DPAgnt.exe. Then click “Rename” from the popup menu.
Step 9: Change the filename from DPAgnt.exe to DPAgnt-BAK.exe.
i hope you do it....
please rate me
thank you.
SOURCE: How to remove the password protection of micro sd
Hello Sanjay,
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FExplorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file.
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
SOURCE: samsung diva phone locked and password forgotten
Try a hard reset: Enter *2767*3855#
You'll probably lose everything on your phone, if nothing was backed up to your SIM card.
