SOURCE: Kpex100/2gb MP4 player
i would suggest to reset it by pressing the reset button with a toothpick.......i experienced the same problem sometimes,but in your case, my brother who also has one,left it frozen and it went dead after a couple of mins. we connected it to the charger then it worked........i hope it will work on you case.
[email protected]
SOURCE: after down loading music player went off won,t recharge
This player is effectively destroyed by using it on a computer that runs either Windows Media Player 11 or Vista. You can try doing a repair in Philips Device Manager, but this is very nearly an obsolete mp3 player.
SOURCE: My battery does not recharge.
I think that your battery is a dud. If you have been using your portable player on ac all of the time then you have been charging your battery at the same time. You need to play the portable on the battery at least once a month or it will slowly just go bad.
SOURCE: cell phone went dead and wont recharge
sometimes when battery becomes full discharged it takes time like hours to come up but over night charge will do it , if it dont check ur battery first if it is ok then ur set is dead there might be software issue seek help from support in ur country
SOURCE: I have a Garmin Nuvi 750. It went dead suddenly.
THERES A GOOD CHANCE THAT THE CABLE IS DAMAGED OR EVEN WORST THE CONNECTOR WITHIN THE UNIT IS DAMAGED OR BROKEN. TRY USING THE OTHER CABLE IE THE CAR TO UNIT CABLE OR THE USB TO UNIT CABLE IF EITHER ONE WORKS THE OTHER IS DEFECTIVE, IF NONE OF THEM WORK THERE GOES TROUBLE.
