Support for 1-************ and How to Dell Alienware X51 running slow disturbs the gaming Desktop, Laptop, tablet etc experience of the users. The slowdown symptoms might be occurs due to number of applications or software installed into the system, outdated drivers, virus attack or infected files creating such issues.
SOURCE: Delete emachinesSystems Recovery and Angels Systems software
You should be able to simply uninstall it in the control panel add and remove programs
Start > Control Panel > Add And Remove > locate the entry relating to the application you wish to install.
SOURCE: installation of softwares
i hope the ipaq is a windows based mobile, or what is also known as pocket PC. If am right, then it will not support .exe applications. Google your requirements specifying that your's is a Windows based mobile..
please revert back for clarifications..
SOURCE: Settings on my laptop to make RPG game run better
Not much can be done for gaming on laptops, unless you shell out over $2000 for a dedicated gaming laptop.
Ram could be a big issue, depending on how much you have. The screen resolution that you are playing at, the detail levels, and possible network connection speed can all contribute to a laggy game experience.
Try turning off any background services that you do not need when you are playing (ie. skype, iTunes, etc...), perhaps checking your video card to see if you have the latest drivers as well.
Testimonial: "Thank you!! I do need to upgrade ram so thats it!!"
SOURCE: I run a emachines EL
try check the device manager in 'my computer' properties. check the sound device driver. if there is no question mark or exclamation mark on sound driver then the main problem not the driver. but if there is, then u have installed wrong driver. try use driver checker program to see what driver u need. hope this useful, regard riyan.
SOURCE: I am using dell vostro1014,due
1. Click on the link
2. Choose the appropriate Operating System
3. Choose Audio and just follow the prompts
Hi Alice Wilson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? OS?
