SOURCE: help
heres a link so you can get more information for your product , hope this helps AJ .
http://www.shopping.com/xPP-irons-norelco~LO-1~CR-0
SOURCE: morphy richards jet stream iron
We have a water filter and softened water. Our iron is clean and went after 2 months.
A Morphy Richards Jet Stream Elite pro.
It is just the steam generator that has gone.
SOURCE: How to use the calc-clean button
Calc-Clean function
The Calc-Clean function removes scale and impurities.
To do so, set the steam control to position '0', set the temperature dial to 'MAX', and fill water tank up to the 'MAX' level. Then heat up the iron until the pilot light on the handgrip goes out.
Remove the mains plug from the wall socket and hold the iron horizontally over the sink. Then press and hold down the 'CALC CLEAN' button.
Move the iron forwards and backwards while boiling water/steam squirt from the holes in the soleplate to wash away impurities/scales.
When the water tank is empty, heat up the iron to dry it.
Finally move the iron to and fro on a piece of cloth to dry the soleplate. Repeat the process if necessary
SOURCE: DG-980 Iron: The button to use the steam is stuck. I was ironin...
Hi Mary, sounds like something jammed in the trigger mechanism or the microswitch button is stuck in the housing. Unplug the iron, let it cool. Gently pry up the blue cushion from the handle from the front towards the rear cord, you will see the trigger, the actuator tab and the microswitch button (nib) that should be sticking out, if it is flush with the housing it is jammed down. That switch is replaceable, but I don't know how savy you or your appliance servicer are at replacing it. Here is where I get my parts:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: [email protected]
Please keep us informed as to your progress resolving this...
check for a short wiring in the terminal of the filament.make sure the terminal is dry no water leak.
