Dishwashers Logo
p
panayiota Posted on Mar 01, 2017
Hi my AEG dishwasher takes 5 hours to complete a cycle. What could be the problem?
1helpful
AEG FAVORIT 35085 Vi dishwasher Beeps 5 times and stops
If your AEG FAVORIT 35085 Vi dishwasher beeps five times and stops halfway through a wash cycle, there could be a few potential causes for this issue. One possibility is that there is a problem with the water supply, such as a clogged or partially blocked inlet valve. Another potential issue could be related to the drainage system, such as a clogged filter or a malfunctioning drain pump. It's also worth checking if the dishwasher's spray arms are spinning freely and not obstructed by any debris. If the problem persists, it is recommended to consult the dishwasher's manual or contact AEG's customer support for further assistance. They can provide specific troubleshooting steps and guidance based on your dishwasher's model and any error codes that may be displayed.
I have an AEG compact dishwasher and it is constantly skipping cycles and I am unsure why. It has 5 or 6 settings plus a time delay. I choose the quick wash (30min) option or the Eco option (108 mi
Good... You are lucky.
RECENTLY REPLACE IT AGAIN...
It should still be covered by a sales contract... and those control boards are not cheap.
(there ARE real silent dishwashers... I promise).
Expecting one to work is not unreasonable...
Keep looking.
Carnac the Magnificent
In which way can i reset my dw AEG favorit F 65450 vi?
Hold and press the end cycle by 5 seconds, and try again. However you can disconnect the c.breaker by 5 seconds too. and try again.
Merry Christmas.
Siemens dishwasher sl33a002uc takes 4 to 5 hours to complete a cycle - what is wrong?
Take the control board out, open it up, and resolder the heater relay or replace the control. It may be under the recall and you can get a new control replaced for free.
AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Dishwasher AEG FAV40620W stuck time delay
Thanks. I figured it out from the online manual. Hold buttons #2 and #3 (second and third button down on far left side) for 2 seconds should reset it. It took some 15 minutes however before the dishwasher reset!
Peter Smith
2helpful
Dishwasher runs for a long time
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
1helpful
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Top AEG Dishwashers Experts
Paul Carew
Dominic Harborne
Level 1 Expert
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
