Heating & Cooling Logo
Cindy Piazza Posted on Mar 01, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
American Standard Freedom 80 single stage fires up... runs and blows heat for a few minutes then shuts off but then 5 minutes later it repeats the cycle. Any ideas? I have replaced the filter.
jack morton
Level 3:
Master:
  • Master 523 Answers
  • Posted on Mar 02, 2017
jack morton
Master
Level 3:
Master:
Answers
523
Questions
14
Helped
255739
Points
1290
A 5 min run time tells me that it is overheating. Probably a dirty evaporator coil, or a loss of airflow due to blower issues. Or even a high temp safety that is opening prematurely? Tstat is calling for heat so its doing its job. It could be overheating or a fault at any of the components in the furnace. 90 percent of the time its a dirty blower wheel, EV. coil, or a missing filter that's so dirty its cutting off the airflow. Hope this helps!
Bryan Wilson
Level 2:
Habit-Forming:
New Friend:
  • Expert 103 Answers
Bryan Wilson
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
103
Questions
Helped
58617
Points
244
I would take the thermostat off the wall and jumper R&W on the sub base. If the problem goes away its in the thermostat. If the problem is still there it might be time to call a service tech
3answers
Heil h9mpv075f12d1 90000 btu Turns on fine, runs 5-6 minutes at slow fan speed. Then flame shuts off. Then for about 45 seconds fan goes to higher speed. Repeats this cycle over and over.
https://diy.stackexchange.com/questions/130130/furnace-runs-for-about-5-minutes-only-and-shuts-off?rq=1
Why does my furnace run then stop? A common reason a furnace short cycles is because the heat exchanger, the part that heats your air, is getting too hot due to a lack of airflow. Once the heat exchanger overheats, it trips the high limit switch, which shuts the furnace down to protect it.Dec 9, 2016
American standard freedom 90 Light Blinks 3 timesOpen heater door unit works fine
Would need more info, which door are you talking about? Blower door with power switch? At what point in the firing sequence does the unit fail? So the burners ignite?
I have an American Standard Freedom 80 furnace. When I turn it on it runs and runs and then shuts down and then the cycle starts again. It runs but never ignites. I was wondering if there is anything I...
EIther the valve is faulty or the ingiter is corroded or faulty. The inside of the ingniter has a shaft with a probe that keeps heated so it can ignite. It can be corroded.
Top American Standard Heating & Cooling Experts
Steve Sweetleaf
Steve Sweetleaf
Paul Carew
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
