If you need to delete photos from one iPad without affecting your iPhone or other ipad, you have to utilize the 3rd-party tool like Leawo iTransfer. And you can follow the below steps to do that.
1. Connect your iPod device to a computer;
2. Open Leawo iTransfer;
Open iTransfer and it will detect your iPod device automatically.
3. Find photos;
Click "Photos" which is in the contents of "LIBRARY" of iPod and then choose photos you want to delete on the right side of screen.
4. Delete photos
Right click to choose "Delete" button to complete the deletion after you selected those photos.
This way makes you easily delete photos on different versions of iPod nano, iPod touch, iPod Shuffle and iPod Classic as well as other iOS devices. If you don't mind that those photos on your iPod touch will be deleted from everywhere, you can choose the first way to delete them. In the second way, you need to find the folders which are synced with iPod nano first and then use iTunes to complete the deletion and it is no doubt that this is a complicated way. And about the third way-Leawo iTransfer, I think it is the most convenient way to realize the deletion compared with the former two ways. What do you think?
For more details, check: How to Delete Photos from iPod
SOURCE: How do I transfer photos from my computer to my iPad?
When you connect your ipad to computer Itunes must be recognized it .
Make sure itunes version 9.1 installed.
If not then download from this link click here
Make sure ipad is enough charged.Try different usb ports.Makes ure usb cable is working fine.
Uninstall usb drivers from computer then check.For that press windows key +R so you can see run type in run "devmgmt.msc" then press enter.
Then you can see device manger uninstall all usb drivers 1 by 1 then it automatic install usb drivers.
restart iPad, first turn iPad off by pressing and holding the
Sleep/Wake button until a red slider appears. Slide your finger across
the slider and iPad will turn off after a few moments.Next, turn iPad on by pressing and holding the Sleep/Wake button until the Apple logo appears.
Is
iPad not responding? To reset iPad, press and hold the Sleep/Wake
button and the Home button at the same time for at least 10 seconds,
Then check then you can sync it with itunes in computer.
Let me know if you need further assistance.
Thanks for using FixYa.
SOURCE: how do you delete photos from ipad?
To delete photos in 1st generation ipad tap photos,tap photos again then tap photo you would like to remove.When in full mode trash can is available.
For 2nd generation and new ipad,tap photos then edit.Tap each photo to add check then tap delete to remove all checked at once.Please Rate
SOURCE: Can't charge the ipad from the USB charger
To get Ipad to show as charging download Asus AiCharger from web and
restart computer after install.Plug in usb from Ipad and should now show
charging
http://event.asus.com/mb/2010/ai_charger/
Please Rate
SOURCE: delete photos from my apple ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to remove the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to remove from the iPad under the Sync Photos from heading.
5.If you want to remove all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
More detailed guide about how to delete photos from iPad.
www.iphone-mac.com/how-to-delete-photos-from-ipad-camera-roll.html
SOURCE: how do I delete a photo on an IPad?
More info: How to delete a photo on an iPad
