SOURCE: I own a 1999 VW polo. The oil pressure warning light illuminates
hi i had a similar problem with a seat leon {vw golf} it turned out to be a defective oil pressure switch only in this case it was knocking the speedo out try disconecting it and take it for a drive, these are overly complicated cars!
SOURCE: 1996 Mercury 150 Nitro EFI
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
SOURCE: STOP ENGINE-LOW OIL PRESSURE LIGHT COMES ON AFTER INSTALLING NEW
Before making any repairs I suggest you put an external mechanical oil pressure gauge in place of the sending unit and determine what your actual oil pressure is. That will tell you which way to go using real numbers. If this condition appeared suddenly it may not be a large problem, especially as you did not note any knocking etc that goes along with internal wear.
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
