SOURCE: I have a Lexmark Interpret
It sounds like the printer is having problem recognizing the printhead. If you're getting "Printhead Error", make sure you have the latest firmware update. You can download and install it from Lexmark at http://bit.ly/adzmDq. If you continue to have trouble, contact Lexmark technical support. Thanks.
SOURCE: I have the Lexmark Interpret
You can get the software on the link below
http://support.lexmark.com/index?page=product&segment=DOWNLOAD&productCode=LEXMARK_INTERPRET_S405&locale=en&userlocale=PL#1
Good Luck
SOURCE: Lexmark prospect pro205 how do I
If you open the panel where you replace the ink cartridges there is a square hole directly behind the control panel. The area gives you enough space to put your hand under the plastic and you will feel what I only describe as a plastic latch, pull it and you should feel the control panel loosen to then be able to close.
Hope this helps...
SOURCE: When I got the machine I folded the control panel
How do I fold the control panel back into the machine for shipping back to Lexmark. 400 series
SOURCE: my lexmark interpret s405 is
There is a recent firmware update that fixes the problem you are describing. Click on this link: Lexmark Interpret S405 Firmware Update to download the update. If you encounter any problem updating your printer, please contact Lexmark technical support for additional assistance. Thanks.
Please visit the Lexmark website to download and install the Lexmark Interpret S405 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
