I can talk to you in automotive terms, I know nothing about a backhoe.
I can usually lay the starter motor on the ground, hook up jumper cables properly from starter to battery, at the least, it should kick out the starter drive gear and spin. If it doesn't kick out the drive gear, starter is faulty. I don't know if starter solenoid sits on top of starter motor? I replace as an assembly. Did you check flywheel teeth? I've never worked on a backhoe.
