Nikon Coolpix 5200 Digital Camera Logo
Susan Watton Posted on Feb 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Nikon coolpix 5200 will not let me re-set it. When I get the re-set on the screen it just skips past it. I just keep getting ( this card cannot be used ) on the screen & no memory card is inserted
Steve Alexander
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
Scholar:
  • Nikon Expert 165 Answers
  • Posted on Mar 02, 2017
 Steve Alexander
Nikon Expert
Level 2:
Mentor:
Scholar:
Answers
165
Questions
0
Helped
56223
Points
234
If you can read the SD card with your computer, copy (backup) all images on the card to your computer. Make sure you saved ALL images. Then put the card back in the camera and FORMAT it. It is in the TOOL MENU that looks like a WRENCH.
How do you change a nikon camerer coolpix 5200 from belgium to english
I am NOT an expert on this problem as I have never changed languages. Language is typically in the TOOLS menu (Wrench) It you get to settings and English is greyed out then I am stuck. If you have many settings you want to keep please ignore what I say here. One workaround that MAY work is reset to factory settings. It could be one of your settings that keeps language setting greyed out. A reset makes the camera like you just purchased it new.
Nikon coolpix 5200 won't except 4gb SDHC card
Correct. The 5200 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
My Nikon Coolpix 5200 is taking three photo,s not one, what do I do
Do you have the camera set on "BURST MODE" it sure sounds like it, if not you have a bad shutter button.
1helpful
How do i format my 1GB SD CARD FOR COOLPIX 5200 CAMERA
Insert it into the camera
call up the menu on the camera for the settings
select prepare card (format)
Takes about 20-30 seconds for most 1-2 Gb cards
Memory card not working
the card is probably too big . try a 2 gb .. some cameras cant take higher capacity cards
3helpful
Memory card write protected
Solution 1 Card has a protection tab, it could be in the locked position, try moving it. then try in camera.
Solution 2 use a progran like Image Rescue, downloadable from www.lexamedia.com to save images & then re format card
Coolpix 4300 needs driver & update for vista
You can download PictureProject software from this address: http://chsv-soft.nikon-image.com/jpn/software/win/S-P2____-175WU-JPNJP.exe
That is the only Nikon software that supports Vista since your camera is "outdated".
Here is a quote from Nikon site:
  • We had released a Windows Vista-compatible version of PictureProject, v1.7.5, for use with the models listed below, and all models that followed. PTP (models supporting the PTP protocol) and Mass storage USB transfer options can be used for camera connection. However, the camera's transfer button can not be used to transfer pictures over a PTP connection. Set the USB transfer option to Mass storage to enable the camera's transfer button.
    Currently, the new Nikon Transfer and View NX will replace Picture Project as our new Image Transfer and Browser applications. These applications support the same Nikon products as Picture Project.
COOLPIX P4, COOLPIX P3, COOLPIX P2, COOLPIX P1,COOLPIX S10, COOLPIX S9, COOLPIX S8, COOLPIX S7c, COOLPIX S7, COOLPIX S6, COOLPIX S5, COOLPIX S4, COOLPIX S3, COOLPIX S2, COOLPIX S1,COOLPIX L6, COOLPIX L5, COOLPIX L4, COOLPIX L3, COOLPIX L2, COOLPIX L1/L101,COOLPIX SQ, COOLPIX 8800, COOLPIX 8700, COOLPIX 8400, COOLPIX 7900, COOLPIX 7600,COOLPIX 5900, COOLPIX 5700, COOLPIX 5600, COOLPIX 5400, COOLPIX 5200, (COOLPIX 5100), COOLPIX 5000, COOLPIX 4800, (COOLPIX 4600), COOLPIX 4500, COOLPIX 4300, COOLPIX 4200, COOLPIX 4100, COOLPIX 3700, COOLPIX 3500, COOLPIX 3200, COOLPIX 3100, COOLPIX 2500, COOLPIX 2200, COOLPIX 2100, COOLPIX 2000,COOLPIX 995, COOLPIX 885, COOLPIX 775.We do not plan to offer compatibility for COOLPIX 990 OR COOLPIX 880 connection to a computer with Windows Vista preinstalled. Use a card reader or card slot to transfer images.
4helpful
Blinking red timer light
The blinking red timer means that the date isn't set on your camera. Go to the set up screen and set the date. I'm not sure why you wouldn't be able to take pictures, though...
Coolpix 5200 will not read sd card
Hope it's not the reader in the camera, first try rubbing the card contacts gently with an eraser and blowing in the slot. It may solve it, if not looks like an expensiver repair job.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
