Https://www.manualslib.com/manual/512002/Fujifilm-Finepix-S8500-Series.html?page=128
Here is a manual. It may help you. Also a short video on auto focus
https://www.youtube.com/watch?v=AMXotFDJhII
SOURCE: I have FOCUS ERROR ON MY FUJIFILM FINEPIX s6500fd CAMERA
This is just a suggestion, as I am not an expert.A couple of years ago I had a problem with my older, Fuji Finepix camera related to the computer downloads/programming and I found Fujifinepix web site. I sent them an email and they responded and did not charge anything. Could try that..
SOURCE: focus error
You will have to disassemble the unit. 2 screws on 1 side and 1 on the other and 2 on the bottom, pop the back off, being careful of the 2 ribbon cables attached to the rear and unock these cables and remove. 3 screws holding the top circuit board (remove the eye piece first and unplug the 2 cables attached to it) carefully unplug all cables attached to this top board and unscrew and remove (there is one on the bottom of the board that you must flip to unlatch. After you remove that board there is the power board... BE CAREFUL!!! The flash capacitor (the black tube looking unit on the bottom of this board) stores chrge and you WILL feel it if you touch the terminals... it they touch metal you will see fireworks so be careful. unplug the single red and black wire plug and unscrew the 3 screws here You do not have to remove the white plug with the 4 or 5 wires because you can just flip the board over out of the uni.. BE CAREFUL!!. unscrew the 2 silver screws securing the metal plate underneath and remove this plate. now remove the single screw left and pull out the lens assem. Here check 2 places... 1 is he zoom screw (it is behind the long silver panel) and also the focus screw (behind the shorter metal panel. Do one at a time. remove the screws from one of them and carefully lift off the motor plate. for he zoom line to metal ring on the screw into the groove of the lens (Shaped like a V) carefully screw the screws back in bu d ni tighten to tight, leave a LITTLE slack. (1/8 turn from tight). Now for the focus screw, remove the cover and align the ring to encase the top of the V The ring is shaped like < the lens is a > so just allow the rinng on the screw to "pinch" the top of the lens groove. secure like you did the other plate (dont forget to back out 1/8 of a turn) reassemble the opposite of disassembly and you are done... it look hard but it is actually pretty easy... any uestions email me at [email protected]
SOURCE: My FINEPIX s1000fd fujifilm camera
pls update firmware issue will be resolved most likely and pls rate me fixya for help
http://www.fujifilm.com/products/digital/download/s1000fd/fupd.html
SOURCE: HOW CAN I FIX MY LENS ON MY FUJIFILM FINEPIX J15?
The only thing i can think you could do is bring it to a repair shop they will repair it for free if there is warranty on it.. hope this helps
SOURCE: fujifilm finepix a820 zoom error
This problem is related to the malfunctioning of zoom motor, Two possibilities are there,
1- If company provides technical help on component leve in your regionl then zoom motor may replace.
2- If component level support is not available then LENS ASSEMBLY must be replaced.
Contact your nearest fuji service centre or contact any expert nearby for the specific part replacement.
Thanks for using fixya.
Testimonial: "thankyou for your advice"
