I believe you are speaking about this
http://www.snopes.com/politics/quotes/trumanpc.asp
SOURCE: how to lite the gas
When you turn the thermostat on the pilot light goes to secondary flame. The flame kicks on to the oven safety valve thermocouple. When it gets hot enough it generates millivolts and opens the safety valve. Here's how to check it; Make sure the flame kicks down and covers the bulb of the thermocouple. You can use a lighter if you're not sure. If no gas comes out It might be the valve that's bad. Now, some of the older models used a flame switch. It looks like a dryer thermostat with two wires on it and the thermocouple coming out of the middle. To check it, short the two wires together or use a ohm meter to see if it's closed.
SOURCE: polit light goes off after 15 minutes,must relight
Replace the thermocouple. It is going bad.
SOURCE: gg40t6a polit light will only light when polit
Does the gas flame fully heat up the coupler
if not then clean out the gas jet nozzle
if yes then replace the thermo couple
SOURCE: political analysis solution manual
Contact SPSS Worldwide Headquarters
SPSS Inc.
233 S. Wacker Drive
11th Floor
Chicago, IL 60606
Tel: 1.312.651.3000
8:00 a.m. – 5:00 p.m. CST
to order documentation.
